non-functioning 4x4
Old Jan 7, 2009 | 01:19 PM
Lower_Level's Avatar
Lower_Level is an unknown quantity at this point
Default non-functioning 4x4
Hello! Am new to the forum; and have been doing alot of reading this morning. Excellent resource here for the DIY'er!
I recently bought a 1996 GMC Jimmy SLT out of a field for $350. Mint interior; solid body; needs some motor work. But it's a project for me to tinker with over the winter.
Now with a $350 gem like this I expected to have some other "issues" than what was disclosed by the previous owner. And aparently not uncommon to alot of these trucks; the push button 4wd doesn't function properly. From what I can diagnose the truck will not go into 4hi, and will only go into 4lo with alot of button pushing & effort. But when the 4lo finally activates, the rear diff locks and the front driveshaft locks. In any other setting; only 1 wheel spins in the rear and the front driveshaft spins freely. I do not think that the front tires engage in any setting. Now as I said; I have been doing a bunch of reading and later tonight when the weather improves I will be inspecting the vacuum lines & diaphragm under the battery as well as lines on the transfer case.
One issue that I have not read alot about is this: my 4wd switch will only operate with the truck in neutral. If it's in gear or park, pressing the buttons does nothing; no lights flashing, no sounds etc. When the trucks in neutral pushing the 4hi or 4lo button causes both lights to flash (possibly all 3 - I think the bulb is out on the 2hi) and then they all go out; but there is sounds of engagement/disengagement of something, I would assume trans. case.
Is that the symptoms of another issue?
Any help would be hugely appreciated!
Old Jan 7, 2009 | 02:08 PM
Default RE: non-functioning 4x4
It sounds like you may have a faulty switch. You can find a schematic and test the switch with a multimeter set to test continuity.
The only switch which is prohibited when in gear is a range change (either 2HI or 4HI to/from 4LO). A range switch should be allowed in both park and neutral, but park may result in a gear mismatch and a failed shift.
rtk3
Sep 9, 2014 04:00 PM
daycock
Mar 17, 2011 10:58 AM
1998LS
Jun 11, 2009 05:22 PM
rastaskater
Feb 29, 2008 07:08 AM
Marzocchi65
Nov 24, 2006 04:26 PM
