Old May 10, 2007 | 11:23 PM
pmeloy56's Avatar
pmeloy56 is an unknown quantity at this point
Default Off Roading
I have a 1998 blazer 4x4 and i have been off roading a few times. I was wondering what i should do to make it able to do more off-roading. I new and just want to make nothing will go wrong if i keep going off roading.
Old May 11, 2007 | 04:36 AM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: Off Roading
Disconnect swaybars, beefier tires, lock the rear, skid plates, depends on how extreme you want to go. If you really want to get into it, you can do a solid front axle swap like i plan on doing after all my other projects are done[sm=badbadbad.gif]
Old May 11, 2007 | 06:09 AM
Shade's Avatar
Shade is an unknown quantity at this point
what exactly are the sway bars? and what the hell do they do
Old May 18, 2007 | 09:43 PM
Hanr3's Avatar
Say bars stop the truck from swaying in turns. They also limit the amount of suspension flex, and on an IFS truck you need every inch of flex. The sway bar is a bar that runs from one front tire to the other front tire. It is shaped like a big u, or horseshoe.
CBlazer99
Nov 8, 2009 05:30 PM
Logan
Nov 6, 2009 07:01 AM
JRR_11
Apr 16, 2007 12:04 PM
user 1016
Mar 4, 2007 11:19 PM
