offroading question
Old Oct 13, 2014 | 10:51 AM
DesertStorm's Avatar
Default offroading question
when offroading (in lots of mud) is it better to have the best tires on the front or on the rear?
i have all terrains on mine, but my alignment was off and now i have some wear on the inside edge of my right front tire... the tires only have a few thousand miles on them, but the RF is worn down pretty bad on the inside edge. should i leave that on the front so i have more traction in the rear? or move it to the rear so i have more traction for pulling....
thoughts?
Old Oct 13, 2014 | 12:34 PM
abig84's Avatar
guess it can go either way. on mine i run the better tires in the back because i have the rear axle locked and figued thats where i want most of my traction and it should save a little wear off the front end.
where as a normal truck i would think id want them in the from where most the weight is and you have traction steering.
Old Dec 26, 2014 | 10:41 AM
baja1000's Avatar
baja1000 is on a distinguished road
You need 4 good tires when off-roading
Logan
Dec 3, 2009 12:11 AM
AllEiz0nMe
Mar 13, 2009 09:36 PM
FarkDaNarc
Nov 20, 2005 07:04 PM
zero psi
Oct 17, 2005 05:00 PM
m00nwater
Sep 23, 2005 04:38 PM
