Onboard air?
It's cordless
^ That's the direction I'm leaning. Their medium kit (up to 33") is only $300 in ebay. Kinda seems expensive, but that is everything you should need to bolt it on. No running back and forth to home depot for fittings, bolts, etc. And everything is brand new, so you don't have to worry about your compressor taking a dump on you in a month or two.
I hope to be ordering one in the next few months. If I do, I'll definitely take pictures and post a write up.
VIAIR Corporation - 300P Part No. 30033
VIAIR 300P Portable Compressor : Amazon.com : Automotive
Check out this thing! My buddy just showed it to me 120 psi and aired up his 33s fast! It's just got two clips to hook to the battery when needed and an air chuck on the side. $60-70 is what he said it costs. That's all I know about it lol. I'm sure google will help out.
made by Q industries, found it on "all things jeep".com
specifications:
maximum amperage: 30A
maximum psi: 150
flow rate: 2.54 cfm
air volume: 4389 cubic inches per minute
dimensions: 12 l x 8 w x 9 h inches
weight: 11.00 lbs
voltage: 12 volt
weight: 11.00 lbs
m $69.99
there are many models to choose from.
the MV90 claims to inflate a full size truck tire in 1.5 minutes
specifications:
maximum psi: 150
flow rate: 2.54 cfm
weight: 11.00 lbs
voltage: 12 volt
weight: 11.00 lbs
m $69.99
jojocarreno
Jul 1, 2010 07:30 PM
mohawks76
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Aug 27, 2009 05:26 AM
dimmuborgir6nik6
Oct 2, 2008 06:51 AM
