Sagging rear.
Old Jan 8, 2008 | 08:59 PM
94NDTA's Avatar
94NDTA is an unknown quantity at this point
Default Sagging rear.
I've noticed the rear on my blazer is sagging a bit. I have also noticed that all of my shocks are shot.
I'm not looking for it to be an extreme off-road machine, but I will be using it for hunting and fishing and to get to hard to get spots.
What can I do to raise the rear just a bit, and what are some good affordable shocks that will work well when driving on the highway, and when I am going off-roading.
Old Jan 8, 2008 | 09:11 PM
Zasder's Avatar
Zasder is an unknown quantity at this point
Default RE: Sagging rear.
you could buy aftermarket shackles that could raise the rear around 2 inches.
Old Jan 8, 2008 | 09:14 PM
94NDTA's Avatar
How does aftermarket shackles affect the ride, shocks, drivetrain, etc.
Old Jan 8, 2008 | 09:26 PM
Zasder's Avatar
Shackles leave the ride quality the same...
Add a Leaf which also raises the rear gives a more stiffer ride...
while an air ride will give you a smoother ride, but costing a lot!
If you want the front higher you can do a T-bar crank, which is for 4wd blazers, 2wd have springs...
cranking the t-bar makes the front end wear faster!
Or you could go the bodylift route ($200ish) and life the entire blazer 2-3" this will not affect the ride quality or cause premature front end wear.
Old Jan 9, 2008 | 10:47 AM
quinnman105's Avatar
quinnman105 is an unknown quantity at this point
Look at Monroe shocks that too expensive. I've got those on mine blazer
Old Jan 10, 2008 | 06:37 PM
myronhntr80's Avatar
myronhntr80 is an unknown quantity at this point
I've got Monroe reflex monotube truck shocks and they are quite nice riding.
swdockter
TrailBlazer GMT360/GMT370 (2002-2009) Tech
17
Mar 17, 2012 01:33 AM
Benedict1337
Suspension Tech
Jul 7, 2010 12:38 PM
Lumpo
Jun 12, 2010 09:15 PM
brandon82490
Feb 8, 2009 09:23 PM
HDogg
Sep 5, 2007 01:21 AM
