SAS how to?
Old Mar 28, 2006 | 11:36 PM
fzr confused's Avatar
fzr confused is an unknown quantity at this point
Default SAS how to?
well, we jacked up the truck tonight to make sure the 4wd worked....well, it does NOT. the front driveshaft does spin, but the tires do not. this is with the entire truck on jacks. you can spin 1 tire and the other not move. also while in drive you can spin both tires backwards. so, since i assume the front diff is SHOT, i guess the SAS will be coming starting saturday. we have a donor truck, a 72(ish) jeep wagoneer. we will be taking the axle out of the front and rear of it. anyone know if these will bolt up easy? we will be getting these for free, so you cant argue with that . also, what about the tranny and t-case? would those swap? anyone know of a "how to" on doing a SAS? the jeep will are getting is on a buddies land and has no motor, he just pulled it to replace the motor in his buggy. he said its free if we can get it on saturday. i know the tranny and t-case that came stock on the blazer will not handle 38's for too long....please help as i have NEVER done anything like this. approx how long should it take? months? weeks? we will work on it a few days a week.....
Old Mar 29, 2006 | 05:07 PM
Default RE: SAS how to?
also, a question to add. with this SAS we will be installing some "large" blocks for some lift. i want to run ladder bars for it. anyone know a good site to buy them from? also, would i look for a set that fits the 91 blazer or a set that fits the 72(?) wagoneer? maybe a universal kit just weld into place?
Old Jun 16, 2006 | 01:38 PM
mtncrsr's Avatar
mtncrsr is an unknown quantity at this point
well first of all you are in for a lot more work than you think! The perches will have to be removed and relocated.Shock mounts will have to be moved.Brake lines adaped (i dought thread patterns are the same).Is the front third member on the same side as your stock drive line oh and you will have to modify your drive lines also.and you will have to adapt your parking brake.
any more questions and just holler
Old Jul 6, 2006 | 04:00 PM
Hanr3's Avatar
Hows the swap coming?
Got any pics?
Check out S10Extremists for all the swap info you will ever need.
Click here
jstables
Jan 15, 2010 09:30 PM
jacobcnc
Suspension Tech
Dec 22, 2009 07:15 PM
wlorton
Lifting Tech
Dec 4, 2009 09:08 AM
blazer_in_ky
Lifting Tech
Nov 8, 2009 09:38 AM
xtreme821
Oct 12, 2009 12:32 AM
