Wheel spacing
Old Mar 10, 2012 | 10:34 PM
Jase1979's Avatar
Jase1979 is on a distinguished road
Default Wheel spacing
I know everyone has already asked this but my answer was not found after many hours of searching, I have a 1998 4dr blazer stock suspension, About to order a 2.5" RC suspension lift with a 2" body lift, I already have the 31" tires in the shed, my question is do I need wheel spacers to keep the tires from rubbing, also will it look stupid without the tires being off set, I really want to keep the factory wheel.
Old Mar 11, 2012 | 01:39 AM
duxtoyz's Avatar
duxtoyz is on a distinguished road
ul need a 1" spacer or ul rub at full lock on the sway bar and frame and even ur fender. u still may need to trim ur fender a lil.
Old Apr 6, 2012 | 08:39 PM
bman's Avatar
bman is an unknown quantity at this point
Default lifting blazer
i have a 1998 4dr blazer is there a lift that will work with the stock independent suspension on the front end or do i have to swap it to a solid axle or any other suggestions
i was wanting to put a 2-3 inch suspension lift and 2 in body
Old Apr 6, 2012 | 11:22 PM
tibby's Avatar
Default .
There is a 2.5 inch lift kit from Rough Country, and other companies makes a 5 and 6 inch lift kit for the ifs. And then performance accessories makes a good 2 inch body lift.
But for the price of the 5 or 6 inch ifs lift, you can do a solid axle swap, so that is something to think about.
jmparker82
Tires and Wheels
May 26, 2014 01:17 PM
Blazerowner100
Tires and Wheels
Aug 26, 2013 05:31 PM
hitechracing
Jan 18, 2010 03:08 PM
Cavalier z24
Tires and Wheels
Mar 22, 2009 02:22 PM
00BlackBlzr
Tires and Wheels
Nov 30, 2008 05:49 PM
