2002 blazer door spring
Old Mar 19, 2015 | 05:05 PM
Wamc's Avatar
Wamc is on a distinguished road
Default 2002 blazer door spring
i have a 2002 blazer and the drivers door will not stay open. is this due to worn out spring.
How due you replace the spring is it that hard?
thanks
Old Mar 19, 2015 | 10:17 PM
Jamaroon's Avatar
you need a door spring compressor, but no it's not hard. it might be that the other piece is corroded and not moving freely though.
Old Mar 20, 2015 | 02:44 AM
Wamc's Avatar
my door opens and closes without any problem. it is just when it is open it will slowly go closed like there is not tension to hold it open.
does this sound like the spring?
watched some videos on how to replace and does not look to hard. Just want to replace the right part.
Old Mar 20, 2015 | 07:01 AM
Jamaroon's Avatar
The spring pushes against a part that rotates, if that's seized it could cause the problem. I would look at that before replacing the spring.
blanco36
Mar 6, 2012 01:14 PM
ABN31B
18
Apr 26, 2011 09:56 PM
jambalaya
Aug 31, 2010 12:34 PM
RevoJer
Jan 24, 2009 10:04 AM
Jman
Jan 24, 2006 09:51 PM
