96 Blazer
Old Jan 26, 2010 | 12:10 AM
LarryMartin830's Avatar
LarryMartin830 is on a distinguished road
Dose anyone know some info on them?
I picked up a 96 but....i been seeing 2 different styles of headlights for the same thing
I have these
But these are for the 96 also what gives?
nevermind i think i understand it now..... 4 doors get the bigger lights and the 2 door get the square..now my question is can i put 4 door ones on a 2 door?
Old Feb 23, 2010 | 10:38 AM
beefgravy's Avatar
beefgravy is on a distinguished road
No not at all, I have a 96 with the same headlights as yours and its a 4 door. I want to do the swap to about a 2000's headlights to get that built in white fog/driving lights. I hope the fenders are the same, and I did just notice if we do the swap, the bumpers are different as they relocated the turn signal into the headlight assemply intead of the bumper.
Sounds fun though.
Old Feb 23, 2010 | 03:43 PM
Psychropod's Avatar
Psychropod is an unknown quantity at this point
The blue Blazer has "sealed beam" headlights, and the red one has "composite" lights.
My four-door 96 came with the sealed beams, like yours, but I did an H3 conversion, which is cheaper than the 98+ upgrade. It will require that you get the housings and H3 bulbs. It will require some cutting and crimping, though it's easier than you might think. You also may need to feed new wiring to the lights, as the factory wiring is poor quality and may trip your headlight relay, as it did with mine.
If you intend to do the 98+ conversion, be sure to run a Search first, because many people on this forum have done it already and can tell you exactly what parts you need and how much effort is involved. I opted to keep my truck looking like a 96 out of respect for the 96es -- but it's your truck, and you should do whatever makes you happy. Hope this helps.
Old Feb 23, 2010 | 06:09 PM
beefgravy's Avatar
That helps me! Thank you.
I have tried searching a bit,and have looked under grill swap, 2000 swap, and others, nothing comes up but what I have already found. Any way you can tell me where to go? Thanks.
Beef
Old Feb 24, 2010 | 01:24 PM
Psychropod's Avatar
Try "98 Front End Conversion." I believe all the parts you will need from a 1998 or later truck are:
  • 1 set of 9005 bulbs (high beams)
  • 1 set of 9006 bulbs (low beams)
  • Headlight Wiring Harness (oh yeah, I have this! Click here!)
  • Headlight Housings and Brackets
  • Grille
  • Radiator Bracket
  • Bumper Valance
You might be able to get everything you need from a junkyard. I have the wiring harness if you want it, but I will tell you in advance that it's a little different between model years where the headlight harness plugs up, so you may need to modify it a little.
Old Feb 24, 2010 | 02:57 PM
beefgravy's Avatar
Sweet man thank you so much.
Old Feb 24, 2010 | 03:10 PM
Psychropod's Avatar
No prob!
Old Feb 24, 2010 | 03:39 PM
beefgravy's Avatar
WOW! I just called like 3 different places, looks like about $400 - $600 for this little upgrade, I will put that one on the back burner, I thought cash for clunkers would help...lol
Old Feb 24, 2010 | 08:41 PM
boomtruck97's Avatar
boomtruck97 is an unknown quantity at this point
http://www.compnine.com/vid.php
another person posted this but and i saved the link.
you go on hear and punch in your VIN and get all kinds of info.
all the stock vehicle specs, including stock diff gears and where it was made.
its easy and kinda fun. lets you know all sorts of info about your truck.
