Powder Coat Spare tire rack.
Old Feb 23, 2010 | 02:28 PM
Izzy207's Avatar
Izzy207 is an unknown quantity at this point
Default Powder Coat Spare tire rack.
I have a 99 Blazer and the rails that hold the spare tire is rusting and chipping at certain corners. I was thinking of getting it re-powder coated. Does anyone know how much it would cost to get the rack re-powder coasted? Or if anyone has a better idea on how to cover these areas it would be greatly appreciated.
Thanks..
Old Feb 23, 2010 | 03:03 PM
ABN31B's Avatar
well im a fan of rubberized undercoating, and an even bigger fan of roll on bed liner...
BUT
to powder coat, i would jump on craigslist... there is a guy about 20 minutes from me that will single stage powder coat 4 rims for $100... i'm sure something like a spare tire carrier (prepped) would run maybe $25 bucks or so... then $4 later you can clear coat it with a rattle can if you so choose...
hit up craigslist and check out your area.
Old Feb 23, 2010 | 03:24 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
I just used POR-15 on my (NEW) gas tank to keep it from rusting, according to their website you can paint this stuff right over rust and it will stop it forever. I brushed it on my tank and it came out so smooth and glossy, i could see my reflection in it. I plan on doing the same to my spare tire cover and roof rack in the spring. The paint also covers alot of area, i only bought a pint and did two heavy coats on my tank and i still had 95% of the can left! I would highly recomed this stuff to anyone! the only bad part is that is really expensive and you have to prep the metal really good. I paid $35 for a pint at my local autobody parts store but you could probally find it online for a cheaper price.
Old Feb 23, 2010 | 03:29 PM
Rogue's Avatar
Rogue is on a distinguished road
Thought POR was not supposed to be subjected to UV = sunlight.
Maybe they changed their formula since the last time I used it.
Other then that it is great, tough stuff.
Just checked their site. Guess you will be ok if you top coat any exposed areas.
Old Feb 23, 2010 | 03:36 PM
sorry, forgot to mention that if you are using it on surfaces that are going to be exposed to sunlight then you need "Blackcote" to go over the POR-15 to protect from UV rays. Thanks Rogue, that totally slipped my mind!
Old Feb 23, 2010 | 03:42 PM
Rogue's Avatar
Just trying to help what little I can where I can.
Old Feb 23, 2010 | 05:39 PM
The_Beast's Avatar
The_Beast is on a distinguished road
I used rustoleum hammered spray paint and got some pretty good results
Old Feb 23, 2010 | 05:40 PM
wlorton's Avatar
I think it was 50 bucks a tire here for two tone powder coat... price could be region dependent as well
Old Feb 23, 2010 | 05:44 PM
Looks great! Good job!
Old Feb 25, 2010 | 01:12 AM
Bails27's Avatar
Bails27 is on a distinguished road
I had mine powdercoated about three years ago and it was in the $100.00 range for the rack and its brackets. It has held up very well and still looks new even with the abuse of children, keys and hockey sticks! Painting it yourself is an inexpensive alternative, but don't skip the prep work. One bit of advice if going the powder coat route- remember to get your pins and bolt heads done and then tap in the pins with a rubber mallett, or you will end up painting rusty pin and bolt heads with a Q-tip like this guy I know... LOL
RobRad
Mar 24, 2014 06:08 PM
tri94bbc
Jun 10, 2011 10:14 AM
matt92
May 24, 2011 02:13 AM
KLBlazer07
Feb 12, 2007 12:18 PM
nails5240
Jun 11, 2006 04:24 PM
