aftermarket heated seats?
Old Dec 8, 2012 | 01:13 PM
Asuryan9's Avatar
Asuryan9 is on a distinguished road
Default aftermarket heated seats?
Does anyone have any seat heaters that you can put oon over your cloth seats? If so which brand? So many choices. Also can you put seat covers over them? So you don't see them asmucg and I can protect my seats from getting dirty lol.
Thanks all
Old Dec 8, 2012 | 01:27 PM
Diaita's Avatar
Old Dec 8, 2012 | 05:03 PM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
Originally Posted by Diaita
Interesting, how did you wire them up?
Old Dec 9, 2012 | 04:08 AM
Diaita's Avatar
Positive on the load side of a relay to the pos stud on fender, negative to chassis. positive on coil side of relay to radio acc wire, negative to chassis through supplied switch.
Old Dec 10, 2012 | 06:38 PM
dirtdog's Avatar
dirtdog is on a distinguished road
Default aftermarket heated seats.
So, I bought a set of the aftermarket heated seats on ebay and Im attempting to install. I have the seats out of the truck. they are factory power and leather seats but no seat heaters. I'm having trouble getting the seat cover off because I cant remove the base of the seat. The bolts mounting the base of the seat are actually faced upwards, so the nuts are on the top side of the seat. the back ones are actually in the foam of the seat. Has anyone tried this yet with their blazer? Any tips would help.
UPDATE. I managed to get the seat covers off and it was all down hill from there. I plan to post pics of the install and a little write up when Im done.
Old Dec 10, 2012 | 06:50 PM
Diaita's Avatar
You should be able to get the covers off if you remove the seat backs(1 bolt on one side, 2 on the other) and remove the sliders(4 bolts). the drivers seat you will need in the raised position to make it possible to get to all the bolts. once you get the sides pulled up, you can release the little rings that hold the fabric down with a pair of needle nose pliers. twist the opening in them wider and rotate them around until it comes off the wire.
Old Dec 10, 2012 | 10:40 PM
dirtdog's Avatar
It took some doing but once I got the seat back off the covers came off easy enough. You just have to make sure not to pull the velcro off of the foam. I plan to post a few pics, I didnt have to even fully take the seat back cover off, I was able to slide the heating element up into the seat.
Old Dec 14, 2012 | 12:25 PM
dirtdog's Avatar
Here's a pic of the bottom and the top half of the seat with the heating elements installed. It also shows the velcro that attaches the seat cover, if you're attempting this just make sure to hold the velcro on both sides, so it doesnt get ripped from the seat foam.
Attached Thumbnails aftermarket heated seats?-2012-12-12_17-32-47_974.jpg   aftermarket heated seats?-2012-12-12_17-42-33_302.jpg
Old Dec 14, 2012 | 12:29 PM
dirtdog's Avatar
This is a pic showing where I mounted my switch, It seemed like the best spot and pretty easy to keep the wires hidden under the center console.
If anyone has an specific questions or want certain pics let me know. The seats are now both completed and I'm really happy with how it turned out. I dont see why this couldnt be done on cloth seats as well.
Attached Thumbnails aftermarket heated seats?-2012-12-12_16-56-01_765.jpg   aftermarket heated seats?-2012-12-12_16-55-44_478.jpg
1997GreenBlazer
May 20, 2021 09:00 AM
chris015
Jul 8, 2012 01:19 AM
pintorio
Mar 1, 2010 10:12 PM
kbaldwin
Dec 29, 2009 07:24 PM
aldend123
Aug 19, 2007 10:20 PM
