Another Hinge thread
Old Sep 12, 2015 | 04:38 PM
Decoy205's Avatar
Decoy205 is on a distinguished road
Default Another Hinge thread
Hi All,
A while back my hinge pin bushings must have failed. I never noticed it but then around Christmas the door got stuck and I forced it closed and pushed the spring out and bent the pin that holds the spring on the bottom of the hinge.
Obviously I need new hinge pins and bushings but I also need the pin that goes on the body side of the hinge with the little wheel that the spring bar? Rotates on.
I have the spring and two new hinge pins and I'm going to order the oversized bushings (thanks to this place I found them) but I'm not sure if I'm screwed with the the other pin being bent.
Here's a pic of my upper drivers side hinge:
It's hard to see in the pic but the bottom of right pin is bent towards the front of the truck. Do I need to get all new hinges now or is there a place to get that other pin? Or do I have to buy a whole hinge assembly to get that piece?
Thanks!
-John
Attached Thumbnails Another Hinge thread-b4867395-7ef4-48af-abc2-aa95ab9a1be8_zpsvldnlece.jpg
Old Sep 13, 2015 | 10:05 AM
Decoy205's Avatar
No responses so far I guess I'm screwed ha! Even if I buy a new hinge assembly I'm not sure if that spring pin piece is removable.
Any advice here is appreciated!!
Old Sep 14, 2015 | 07:30 PM
Decoy205's Avatar
Found the piece on the total automotive site. Figured I'd post it here in case anyone runs into the same issue:
Catalog :: Total Automotive Hinge Kit Solutions
Part number: TAI - GMRP04
wlorton
Lifting Tech
Jan 26, 2010 12:28 AM
uncle larrys oranges
Tires and Wheels
Jan 19, 2010 05:56 AM
Weedenski
30
Jun 3, 2009 10:57 PM
cr8390
Tires and Wheels
Feb 18, 2009 05:35 PM
02 Vortech
Nitrous, Super Chargers, & Turbos
Oct 13, 2008 07:38 PM
