Body mount bushings
I'm willing to bet you have more than 4 bad. They might look fine but once you replace with the new you will find out they have sagged or they fall apart when you loosen them to put the new ones in. The rubber gm used degrades pretty fast.
Well, I got the bushings, to do the cab mount, but how the hell do I get the old bushings out on my 93 jimmy 4wd? Is there a bolt with a nut? or is it just a bolt, because I pulled back the carpet and could not find a nut on the top side?
my local gm stealership wanted $35.00 for each body mount, then i found a energy suspension full body kit online and was a lot less costly. scense i was doing a body lift i may as well do the mounts also..
Paul Bell
Oct 13, 2011 06:56 AM
Diverknox
Mar 4, 2010 10:05 PM
95Blazer4x4
Feb 1, 2008 08:19 PM
