body swap
Old Aug 23, 2009 | 07:36 PM
csutton419's Avatar
csutton419 is on a distinguished road
Default body swap
Has anyone attempted a body swap or taking a the body off of an older blazer?(1978) My body has a lot of rust and i found another 78 with a good body but no motor or trans, any insight will be awesome
Old Aug 23, 2009 | 08:02 PM
It would be pretty easy using the same year bodies... A few friends to lift up the tub and you should be good. Just get the body mounts loose and disconnect the steering, transmission linkage, and wiring, then lift it up and over. Practice on your rusted out body!
You will want to check with your local DMV first though as the official VIN tag is tied to the body of the truck.
Old Aug 24, 2009 | 03:54 PM
csutton419's Avatar
Thanks for your help, my blazer hasnt been registered in my name yet, its been off road use only, but if i use the title from the donor body to register with dmv and tags i should be good right?
Old Aug 24, 2009 | 07:21 PM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
theoretically, but only the Louisiana DMV will know for sure!
Old Aug 24, 2009 | 08:30 PM
I would still check with your local DMV, but if you have a clean title for the other body, I would think it would be no problem.
Jamieson
Sep 17, 2013 10:13 AM
Jamieson
May 27, 2013 05:41 PM
hrn006@aol.com
Jan 6, 2010 06:33 PM
jl7030
Mar 23, 2009 07:04 AM
91 Streeter
Engine & Internal
Feb 1, 2007 10:56 AM
