changing low beam light bulbs
Old Feb 16, 2007 | 02:32 AM
scblazer's Avatar
scblazer is an unknown quantity at this point
Default changing low beam light bulbs
Newbie here...how do i change the low beam light bulbs. I bought 9006 bulbs and can't figure out how to remove the headlight assembly.
Any help would be appreciated.
2001 Chevy Blazer
Thanks
Old Feb 16, 2007 | 02:50 AM
Chevy Lover's Avatar
Default RE: changing low beam light bulbs
Welcome to the forum.
Open the hood and you should see a couple of retainers, pull them up and out and the headlight will tip forward and come out. Then rotate the back of the bulb couter clockwise and it will come out. Don't touch the glass on the new bulbs or they will burn out prematurely due to the oils in your skin.
Old Feb 16, 2007 | 08:55 AM
drperry's Avatar
Make sure that, when you put the headlights back in, make sure they're sitting level, and the bottom clips are all the way in.
Old May 27, 2007 | 07:45 PM
MCamill510's Avatar
MCamill510 is an unknown quantity at this point
Is there a trick of some sort to get them back in? I have tried several times to get the passenger side unit back in properly and it just will not seat properly!
Old May 27, 2007 | 11:52 PM
drperry's Avatar
Luck, mostly, if you didn't take the grill off...
Did you try it with the grill off? You'll be able to see the bottom parts that you need lined up...
Mike4x4ing
Jul 6, 2013 01:21 PM
marine
Jan 28, 2010 07:05 PM
jonesjamesw
Mar 16, 2008 06:54 PM
dimmuborgir6nik6
Feb 27, 2008 01:34 PM
bluesjam99
Feb 17, 2007 03:34 AM
