door is hard to shut
Old Mar 28, 2008 | 09:17 AM
strong blazer's Avatar
strong blazer is an unknown quantity at this point
Default door is hard to shut
sum a** hole hit my 91 blazer while was in the store with the wife and now my driver side door is off i have to pick up an little to close it or slam it so that it would close on the first try what should i do ? oh and because of that parklot hit and run i now have an creast in driver fender near the door gap
Old Mar 28, 2008 | 10:36 AM
WolfPack's Avatar
Default RE: door is hard to shut
Check the hinges...did it actually bend them in, or did it just pop a bushing? Both would cause the door sag. Also it could be the door panel itself just folded and there's a part bent downwards now? Just gotta check it out!!
Old Mar 29, 2008 | 07:18 PM
oh the hinges are bent just was wondering how would i bend them back
Old Mar 29, 2008 | 07:40 PM
Very carefully... I'm sure that you could probably do it, but it will not be easy to get the door realigned properly... You may have to heat things to bend them. The easiest way to do it would probably be to pull off the fender and work the hinges with the door on, checking the fit periodically.
Old Mar 30, 2008 | 09:38 AM
well all i have to do now call up a buddy with an blow torch so i can tackle this problem thanks
Charder
Oct 11, 2012 12:33 PM
Staticxtreme5
Mar 31, 2011 07:43 PM
davtak
Oct 27, 2010 12:34 AM
apross44
Mar 23, 2010 02:09 PM
dankolbenschlag
Nov 28, 2006 04:03 PM
