Gauge cluster with tach for '96 Blazer
Old 12-12-2009 | 09:26 PM
Lidberg's Avatar
Lidberg is on a distinguished road
Default Gauge cluster with tach for '96 Blazer
Hi there,
First time poster, long-time lurker. I spend most of my time in VW and Audi forums. I had a 2002 Jetta GLS and now I have a 2006 Audi S4 (post-deployment present to myself).
I recently acquired a '96 S-10 Blazer from my parents. My dad bought an '08 Compass and between you, me and the tree, I like the Blazer a LOT more. Even though it has 155,000 miles on it, it still runs perfectly.
Anyways, one of the few things I don't like about it is that it doesn't have a tach in the gauge cluster. Every car I've owned had a tach and I'm used to having one there, just to see how fast the engine is turning as well as making sure it's running right. Is there a cluster available for the '96 Blazer that has a tach in it? I've searched this site and Google'd it as well, but it's hard to tell who's trustworthy or not.
I figure at least one person in here has done it so I figured I'd ask here first.
.:Christian
Old 12-12-2009 | 09:51 PM
You should be able to find a tach cluster and drop it in. It must be from either a '96 or '97 truck though. Things changed in '98 with the addition of a few more modules inside so I am not sure if they would be compatible.
Old 12-12-2009 | 10:22 PM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
Like Kyle said its a drop in installation. Here is a pic of mine. Don't look at the dust on the dash.
95 to 97 will fit perfectly
Old 12-12-2009 | 10:50 PM
Lidberg's Avatar
Nice job! Did you have to do anything to get the tach to work? Where did you source it? I found a site that has it for $190 http://www.everdrive.com/skus/JF/119...peedometer.htm. I thought I would hit the junkyards and try to find one.
Old 12-13-2009 | 08:01 AM
I got mine off of Ebay for about $50 IIRC. Took me all of about 30 minutes to install. To make installation easier I dropped the steering wheel down. This makes it a lot easier to remove the dash surround.
No wiring required, plug it in, replace the screws and your tach will work.
Old 12-13-2009 | 12:25 PM
Lidberg's Avatar
That's awesome. Thanks for the info!
.:Christian
Old 12-14-2009 | 01:30 AM
hubbmatt's Avatar
hubbmatt is an unknown quantity at this point
Swapped mine out in my '96 too. Works like a charm!
Old 12-14-2009 | 09:29 AM
Lidberg's Avatar
Good deal. I've got one ordered. It should be here by the end of the week.
Thanks for all the input. It should be a pretty painless install. I've already had the dash apart to install my car stereo, so this shouldn't be much harder.
I did the same gauge swap in my '96 Neon way back when (when I couldn't afford anything better, haha) and I didn't have to do anything to get the tach to work. I installed the cluster and everything just worked.
.:Christian
Old 08-01-2011 | 06:50 PM
MikeRo's Avatar
MikeRo is on a distinguished road
HELP!!!!
So i switched mine over to one with the tach today and i am having an issue....
All of my gauges are off/inaccurate, which is no good.
Is there a way to reset them all to work?
Old 08-01-2011 | 06:57 PM
Lidberg's Avatar
Are you sure it's from 95-97? I swapped mine in soon after my original post and it works perfectly.
