gauge swap for 99 blazer
Old Dec 31, 2007 | 06:14 AM
JustBlaze99's Avatar
JustBlaze99 is an unknown quantity at this point
Default gauge swap for 99 blazer
hey i need some help. i got a bad gauge cluster in my truck. i thought since im already going to replace it i might as well go digtial but i don't were to get it from. can i just buy a digtial gauge cluster or one by one. either way can someone tell me were i can find them at. thax. JUST BLAZE!!!!!!!!
Old Dec 31, 2007 | 01:22 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: gauge swap for 99 blazer
what do you mean by digital? as innot cable-driven?
Old Jan 4, 2008 | 02:10 AM
i mean digtial readout instead of the whole sweeping arm thing
Old Jan 4, 2008 | 02:34 AM
Chevy Lover's Avatar
I don't know enough about electronics to tell you. The wiring may be different and the value requirements may be different.
You might do better to ask at anauto electric company.
My biggest concern would be the connection (and voltage)to the vehicle speed buffer for your speedometer.
The standard instrument cluster contains a microprocessor. The instrument panel cluster (IPC) microprocessor communicates with other controllers in the vehicle over the Class 2 serial data bus. The information passed over the Class2 bus, along with direct external connections to other controllers and devices provides the inputs that are used to operate all of the gauges and the illuminated displays in the cluster. Some displays and gauges are operated directly by external sources (devices or controllers) and others are under software control of the IPC. As the IPC microprocessor runs the operating software, the microprocessor continuously processes Class2 data in order to determine the correct values and states to display.
Old Jan 4, 2008 | 07:10 AM
There is no stock replacement, digital gauge cluster available...
er0ck273
Sep 1, 2013 11:45 AM
grayman63
Jul 17, 2013 01:56 PM
JonZRDeuce
Feb 5, 2012 06:38 PM
hoppy26
Jan 26, 2012 02:08 PM
Mulisha
Mar 24, 2008 09:14 PM
