Halo Projectors
Halo Projectors
I'm Wondering If Theres Anything I Should Worry About Running Into Installing These.... http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
RE: Halo Projectors
Still Wondering If Anyone Has Ran Into Any Probs
RE: Halo Projectors
Common problems with pretty much any aftermarket headlamp like that is poor sealing. Many of them have inadequate sealing between the clear front lense and the rear section, typically just **** poor friction welding. If you do go with these, try to thoroughly clean this area on the outside of the headlamps and then take a good silicone based sealant that hardens up (RTV will do) and get a good coat over this area to minimize the risk of moisture buildup in the headlamps.
Other than that, the look pretty sweet. If no one else has tried them, the you really don't know what the beam pattern is going to be like, not to mention if they are even DOT approved, which may fail you on an inspection depending on the restrictions in your state/area.
RE: Halo Projectors
Ty For The Tips , There Dot Approved I Made Sure First..LOL Same W/My Tail Lights Thats One Thing I Look For
RE: Halo Projectors
i wanna see a pic of what it looks like on ur blazer.. im thinking about getting some halos for mine and i wanna see what they look like. thanks
RE: Halo Projectors
Will Do So, I Was Shocked When It Only Took Me 15 mins To Install But They Look Sweet
RE: Halo Projectors
put a set like these in my sons s10,,look good and no problems,,look real good with just parking lights on..mine are called angle eyes,,
RE: Halo Projectors
DOT approved, but doesn't mean you'll get a bad batch, or the quality didn't go down afterward. Never had problems with aftermarket corners in the Cougar, but had others have problems from the same company. Just depends on the particular ones you get. I say go for it. I've always loved those. Friend has them on his Explorer. They look sweet at night.
