headlight questions
Old Mar 17, 2007 | 09:35 PM
stevelknievel's Avatar
stevelknievel is an unknown quantity at this point
Default headlight questions
i have a 97 jimmy and i plan on putting the 98 and up headlights in. has anyone done this or know of anything special i need to do? it looks like ill just have to cut the headlight buckets out
Old Mar 25, 2007 | 08:11 PM
turboxb9s's Avatar
turboxb9s is an unknown quantity at this point
Default RE: headlight questions
I've done this. I bought a 95 that was in a front end collision and I replaced the parts to give it a 98 headlight set up. You will need the radiator support because that is what the 98 style grille and headlights will fit into, the grille, the headlights, and the blinker/parking lights. The 95-97 bumper can be used but their will be cutouts in them for lights that will no longer be able to be used. If you have sealed headlights as opposed to the replaceable halogen bulbs you may have to convert over to the 9006 or whatever type bulb instead of the sealed beam style. Good Luck!
Old Mar 26, 2007 | 12:17 AM
i believe its time to hit the junkyard
thanks man
and is there an obvious way to see if i have the sealed beams?
Old Mar 26, 2007 | 09:11 PM
turboxb9s's Avatar
the sealed beam type headlighst are set into the grille an inch or 2 where as the ones with the halogen are flush with the oustide of the grille and it looks alot smoother. I believe from 1995-1997 it was an option.
Old Mar 27, 2007 | 01:16 AM
thanks alot guys!
Awesome
Mar 3, 2014 05:10 PM
AGodlyCanuck
Jan 28, 2014 12:43 AM
vankuen
Sep 22, 2007 05:26 PM
psawatsky
Aug 6, 2005 01:48 AM
Ranger Rick
13
Apr 24, 2005 02:50 AM
