Headlight removal?
Old Jan 12, 2010 | 08:20 PM
oktain's Avatar
Default Headlight removal?
I'm planning on installing my HID's in the near future, but before I go breaking clips, I was hoping someone could tell me how to remove my headlights.
I've searched around and haven't really found anything conclusive.
I will be writing up a detailed How To with pictures of all the steps when I do this.
Thanks.
Old Jan 12, 2010 | 08:23 PM
wlorton's Avatar
There are two clips on each headlight... LOL... when I removed the last light on my blazer (other broke off....) I used a pair of pliers and had myself a hard as time until I realized its two clips behind the radiator support... then turn up and pull up i believe.... I felt like a dumbass... it is really easy and can be done in about 3-4 seconds... You just need to do the two clips on each light and you are good... And as a favor can you take detailed pictures of the wiring locations? It would help me when I decided to put the front end pieces on my blazer... Thanks and good luck
Old Jan 12, 2010 | 08:26 PM
NVANZEE's Avatar
Thats easy. All you do is pull the two clips on each side and pull the headlight out. The clips are on the opposite side of the rad support. For installing HIDs you will probably have to remove the grill. For that all you have to do is grab it from under the chrome strip and give it a good pull. It will pull out a few inches then disconnect the wire harness on each of the turn signal bulms
Old Jan 12, 2010 | 08:45 PM
bandidolenny's Avatar
Yep... takes about 5 seconds... very easy.
Old Jan 12, 2010 | 09:15 PM
AJBert's Avatar
Just make sure you when you reinstall them that the two prongs are fully seated. These are not the same as the clips. You'll be able to install the light no problem and seat the clips if you don't insure the prong are all the way in but your lights will look just a bit off. You'll see what I mean once you pull one of the light assemblies out.
Old Jan 13, 2010 | 07:01 PM
oktain's Avatar
Thanks for the pointers! I'm probably going to pull the grille off to mount the ballasts on the rad core support. I'm just looking for a heated garage that I can borrow for an hour or two... unfortunately my 2 garages are filled up with snowmobiles, parts, and ATVs lmao.
Old Jan 13, 2010 | 07:16 PM
wlorton's Avatar
I think someone mounted them on the other side of the radiator support rather than right behind the grill.... Just an idea incase room is an issue...
Old Jan 13, 2010 | 07:46 PM
oktain's Avatar
Yeah, I mis... typed (can't really say misspoke can I? lol) still semi-somewhat behind the grille though...
Old Jan 13, 2010 | 07:54 PM
wlorton's Avatar
It was just a suggestion.. lol.. no fret... But I have my front end pretty much off... still... and I am unsure of the wiring and its flow... If you could take pictures of the stock wiring before you replace... that would be the best thing ever.. right now mine is zip tied up to the radiator support so I could play in the snow... FTW!
Old Jan 14, 2010 | 06:31 AM
Sisk's Avatar
I posted pics of the clips somewhere....might be in my build thread. Let me see if I can't dig those up.
johnjfeher
Mar 18, 2015 12:08 PM
RidnClean
Jun 9, 2008 09:12 PM
Psychropod
21
Jan 29, 2008 02:37 AM
psawatsky
Aug 6, 2005 01:48 AM
Ranger Rick
13
Apr 24, 2005 02:50 AM
