Krylon paint+primer
Old Nov 23, 2021 | 09:14 PM
puttster's Avatar
Default Krylon paint+primer
Wondered if anyone has tried the paint+primer products from Krylon. They have the ColorMaxx, Fusion and Colormaster. Have not been able to tell what the difference in them is, though. I'm looking for a light tan. Anyway, my clearcoat is really flaking off and the idea of not having to prime and clear is attractive. The Krylon site says not for automobile use but I am interested in giving it a try. Looking at the Fusion Satin Khaki. I'd sand off the flaking CC and rough up the existing paint with some 3M red scuff pads, then spray.
Alternatively I could go with Rustoleum Camouflage Sand or Khaki. Only $4 at Walmart, however they probably need primer, and because they are flat, a satin clear of keep the fingerprints off. That's why I'm leaning toward the Krylon.
My hood and roof is wrapped carbon fiber and the lower trim is painted black, so I really just need the middle painted- maybe 4 or 5 cans worth.
Old Nov 24, 2021 | 08:35 AM
I used the satin black on my rear end, er, on my Blazer's rear axle. I painted it over hideous blue paint that somebody had sprayed on there, and it turned out pretty well. It dried pretty quickly, too.
Before
After
Old Nov 24, 2021 | 06:45 PM
puttster's Avatar
Thanks for the post. OK. I'm going with Krylon Fusion.
Old Nov 27, 2021 | 02:21 PM
puttster's Avatar
okay, I did the tailgate. Scotch pad, three layers of spray, 320 grit wetsand. Has stripes if you look at an angle, can't tell if they're from the sanding or the paint nozzle. before I move on I'll get after it with a buffer and polish, see if that evens things out.
Edit. No improvement with buffer. And actually as I was cleaning off the polish splatter from the bumper, which I had sprayed with Krylon Colormaxx, the paint there started rubbing off. Hmm.
IronDobe
Dec 12, 2012 08:33 AM
ProjectICE
Jul 4, 2011 09:38 PM
9Blazer6
The Chop Shop
Jun 20, 2011 01:14 PM
RangerG
Jul 7, 2010 07:39 AM
Krayziess
Mar 25, 2009 03:31 PM
