Leather seats in a ZR2
Old Apr 30, 2010 | 08:03 AM
swizznuker's Avatar
swizznuker is on a distinguished road
Default Leather seats in a ZR2
I have found seats for sale on Ebay:
http://cgi.ebay.com/ebaymotors/2000-...Q5fAccessories
and was wondering whether or not they will fit in a two door?
What about trailblazer seats?
Old Apr 30, 2010 | 09:01 AM
oktain's Avatar
Front seats would fit... rears wouldn't fit right.
Old Apr 30, 2010 | 09:04 AM
HcHawks09's Avatar
only thing i would be concerned about is getting into the back seats, not sure if they fold forward...
EDIT: "Both seats will recline but being from a four door Bravada they do not tilt forward"
They wont work. stated that they do not tilt forward in small print at bottom at listing
I think the tracks will match up, and if not exactly it would be easy to modify it.
The other thing you have to ask yourself is if you're going to wire the electrics, otherwise you would have to bold the seat where you need it to drive. (ie:make it permanent)
Old Apr 30, 2010 | 09:18 AM
oktain's Avatar
If he swaps the seat tracks, IE puts his on the leather seats, he'll still have the manual... forward&back... adjustment lol. Seats not reclining is an issue, but at the same time an excuse to not give anyone rides lmao.
Old May 3, 2010 | 07:42 AM
swizznuker's Avatar
hmm... it seems like more work than is worth it :-\
Thanks guys!
Old May 28, 2010 | 11:37 PM
craigthebull's Avatar
craigthebull is on a distinguished road
I have a 99 ZR2 and I put 97 Bravada Leather seats in it there are a few things you will need they changed the seat belt in 98 so it is mounted to the seat not the floor so if you use older seats like i did you will need to get seat belts to mount to the floor. The hardest part is the part that makes the seat fold and slide formard for back seat access. For that you will need the seat tracks and right side hinge from a same generation as the new seats - got mine from a 97 extra cab truck(also were i got seat belts) a two door blazer will work also. the bolt holes are the same on the 95 - 2005 blazers they just moved the back inside bolt to where the seat belt used to be on the 98 and newer you will have to drill a new hole if you use older seats in a newer blazer but the reinforcement is still there just no hole and bolt the seat belt where the back inside bolt was.You will also have to cut a small slit in the seat for the **** that makes the seat flip and slide make sure to get all of the parts when you get the tracks and hinge. Got mine at pick and pull for $20. For power it is easy a power and a ground is all needed if you can get the plugs it is easyer to put in and take out that way. hope this helps.
blazin_j
Oct 31, 2009 10:00 PM
Tippman7641
Jun 4, 2008 09:23 PM
felonyblazer96
Dec 16, 2007 05:40 AM
flowmasta
Aug 3, 2006 01:34 PM
