My door doesn't close tightly, how do i adjust?
Old Feb 9, 2009 | 04:20 PM
fob505's Avatar
fob505 is an unknown quantity at this point
Default My door doesn't close tightly, how do i adjust?
I have a 2001 blzer off-road i inherited from my father. Anyways the door closes but doesn't sit flush with the body. I can hear the wind and feel cold air coming in thru it. The weather stripping is in good condition. It's about a 1/8 - 1/4 " gap. It's really annoying, because . It's the driver's side.
Has anyone ever messed with the door alignment? If so, please let me know how to do it.
Old Feb 9, 2009 | 04:32 PM
volfan4's Avatar
volfan4 is an unknown quantity at this point
Default RE: My door doesn't close tightly, how do i adjust?
Most likely your door pins and bushings are worn. The doors are pretty heavy on these blazers and the bushings wear out over time. If you do a search for *DOOR PINS*, you should find information on the tools and process involved in replacing them. The parts are usually available at most parts stores in the HELP!/ Motormite section. This is a common problem with the blazer. Hope this helps.
Old Feb 10, 2009 | 06:28 AM
Yep, your bushings and pins are likely worn out.
Old Feb 11, 2009 | 08:46 PM
cr8390's Avatar
cr8390 is an unknown quantity at this point
yep same as above. This happened to me shoot by autozone or somewhere like that there cheap
Old Feb 11, 2009 | 08:57 PM
BudRacing's Avatar
BudRacing is an unknown quantity at this point
A good $10 tool to invest in for this is the GM door spring removal tool. I bought mine at harbor freight and it made a world of difference getting that spring out.
lazer2000
Sep 16, 2012 11:16 PM
big armo
Jan 23, 2012 08:39 PM
fslobodecki@yahoo.com
Dec 12, 2011 11:48 AM
WolfPack
15
Feb 8, 2011 03:36 PM
Jakester91119
Apr 3, 2009 01:11 PM
