Need Help with Striker and post
Old Jan 4, 2018 | 07:42 AM
jeffw5129's Avatar
jeffw5129 is on a distinguished road
Default Need Help with Striker and post
Im not sure if I am posting in the right place, But I need help with my truck. The metal on the pillar where the striker attached was bent and the striker is now ripped out. I have seen people weld a piece of sheet metal on and then reattach the striker, I want to know if anyone else has this issue and if that works. Also, what would be a round-about figure to get that work done? I am in the Philadelphia PA area and I dont really have money to be throwing at this truck if it is going to cost an arm and a leg. I do not have a welding machine nor do I know how to weld so I cannot do it myself. If there is anyone in philly or the surrounding areas that does know how to weld and would like to help I would be happy to pay you (depending on the cost ;p)
Old Jan 4, 2018 | 04:38 PM
Snap-Off's Avatar
Snap-Off is on a distinguished road
That sucks. I tell ya, I own a stick welder , but barely know how to use it. I managed to blow big holes in 1/4" steel plate way back in welding class with an oxy acetyline welder.. So ya sure wouldn't want me touching it..
But here's someone who was in about the same position as you:
https://blazerforum.com/forum/2nd-ge...-4-door-64710/
May give you an idea what you are looking at or for..
Good luck man..
Old Jan 6, 2018 | 09:27 AM
2004 Blazer's Avatar
2004 Blazer is on a distinguished road
Mine had the same problem, apparently. The fix you mention was done on mine by the previous owner. He couldn't weld very well either, looks nasty, but it works.
Old Jan 6, 2018 | 11:26 AM
I could fix it for you, but you would need to travel 3000 miles to get here. Probably not worth it, lol.
Another option might be to cut out the affected area, install the striker into a new patch piece, and hold it in place with a bunch of steel pop rivets. Not nearly as elegant as welding, but it would probably work.
step66
29
Sep 14, 2020 05:45 AM
Ripcord
May 30, 2015 10:25 AM
NT_Hardcore
Apr 11, 2012 01:36 PM
budman802g
May 22, 2011 08:04 AM
s14sh3r
Feb 19, 2011 11:10 PM
