Need some painting advice!
Old May 27, 2019 | 06:46 PM
Matt Evan Cinquini's Avatar
Matt Evan Cinquini is on a distinguished road
Default Need some painting advice!
I just painted my lower part of the door, sanded it down and sprayed it with a spray can and didn’t apply clear coat yet because there is orange peel in some places and a little bit of paint run. Should I just wet sand with 2000 grit sandpaper to smooth it out and if need be apply more paint and then apply clear coat? Or should I apply clear coat to the orange peeled paint and then wet sand it afterwards? I want to make this thing look as smooth as possible!!
Old May 27, 2019 | 07:18 PM
odat's Avatar
Before - reapply as needed - clear coat and if needed lightly wet sand again - Finer grit the better - Rattle can is only going to do so well - Dupli-color holds up well as it has more solids in the paint ....
Old May 27, 2019 | 10:58 PM
Before - reapply as needed - clear coat and if needed lightly wet sand again - Finer grit the better - Rattle can is only going to do so well - Dupli-color holds up well as it has more solids in the paint ......
so just spray the clear coat over the current paint now? And I did use Dupli-color. I just suck at spray paint lol I have dupli-color clear coat as well. Should I wash the dried new paint before applying clear coat?
Old May 27, 2019 | 11:12 PM
odat's Avatar
so just spray the clear coat over the current paint now? And I did use Dupli-color. I just suck at spray paint lol I have dupli-color clear coat as well. Should I wash the dried new paint before applying clear coat?[/QUOTE]
No you miss understood me - Sorry -
Before you recoat or clear coat the area Sand the imperfections out.
Sand, tac rag, recoat, let cure, sand, tac rag, clear coat - sand if second coating or if needed, tac rag if recoating , let properly cure - wax - I perfer Mothers Wax ....
Old May 28, 2019 | 01:09 AM
Wax ....
Oh you’re fine haha I’m still new to painting. The broken down process makes more sense. Now what grit should I use for sanding it down?
Old May 28, 2019 | 12:17 PM
odat's Avatar
At least 200 the finer grit the better esp on finish work .....
The_Beast
Jul 25, 2009 09:53 PM
Cmatt1605
May 22, 2008 12:49 PM
AtreyuManiac
Dec 16, 2007 11:02 PM
blazerrider101
Oct 25, 2005 11:22 PM
timetoblaze
Dec 24, 2004 11:26 PM
