Newbie Question - 03 Grill Removal -BrushGuard install
Old May 11, 2006 | 10:44 PM
Newfiezedder's Avatar
Newfiezedder is an unknown quantity at this point
Default Newbie Question - 03 Grill Removal -BrushGuard install
Hello everybody, I have had my 03 ZR2 for about a month now and last night attempted to install a pushbar/ brushguard with no instructions. After it was all said and done I found it to be shaky, and then noticed the brackets that go under the grill. So I did a lot of reading on here and I think it just snaps in but I want to be sure before I try to pull it off. Also I was wondering if there are any torque specs for the bolts. I got the bar, sidesteps and a bike rack from a co-worker and he does not have the instructions. Thanks for any input
Greg
Old May 11, 2006 | 11:37 PM
MCas86's Avatar
MCas86 is an unknown quantity at this point
Default RE: Newbie Question - 03 Grill Removal -BrushGuard install
if ur co-worker had it installed on a vehicle then just see if he'll help u...otherwise, i believe ur right that the grill snaps on however i'd wait for a more positive reply as i myself have never taken my grill off. u might be able to find it online somewhere...if u search for 2003 grills you might be able to see in a picture if it has snaps or not. good luck, by the way what's ur brushguard look like? take a pic when u finally get it installed
Old May 11, 2006 | 11:54 PM
BlaZeR FXB1581's Avatar
BlaZeR FXB1581 is an unknown quantity at this point
i know my '98 grill just snaps on and off..i would assume yours does too
Old May 11, 2006 | 11:55 PM
Yes, it does just snap out, but you will have to remove the turn signal plugs from the grill section. The headlights stay mounted to the core support. It is kind of awkward to handle so you may not want to try to remove it by yourself. You could end up cutting a wire for one of your turn signal connectors.
Old May 13, 2006 | 12:22 PM
Thanks guys, here it is
Now on to the step bars, post for help coming soon (working on a best guess idea is fun)
Old May 13, 2006 | 12:24 PM
Sweet! Looks great!
Old May 13, 2006 | 01:41 PM
MCas86's Avatar
cool...now ur ready to go run people off the road...haha have fun...and lemme know how much u get ur nerfbars for and where from...im lookin into 'em but i want tube nerfbars not running boards...im extremely picky i know
Old May 13, 2006 | 05:42 PM
I have the side rail/ nerfbars what ever there are called, but I have no instructions, so it looks like I have to drill at leat one hole and mount one side to the body mount (there is a 1" spacer for betweent the bar and the body) and drill one hole for the rear. Here is how I think it goes:
and
for the front mount. For the rear I can line it up with one hole (in the circle) but it looks like I have to drill the second.
Thanks again for any input
Greg
jtbaumgart
Mar 22, 2010 12:58 PM
Unlimitedsp
Feb 12, 2009 07:06 PM
Tippman7641
Jun 7, 2008 08:34 PM
Tippman7641
Jun 1, 2008 06:41 PM
lennyblazer
Lifting Tech
Jul 16, 2007 11:58 PM
