Rear window trim
Old Oct 1, 2012 | 12:25 PM
gbvinla's Avatar
gbvinla is on a distinguished road
Unhappy Rear window trim
I am sure someone on here has done this, but I need to paint the plastic rear window trim on my 02 Blazer. What is the best method to seal them and smooth out the rough texture? It has obviously been kept outside previous to my purchase.
Old Oct 1, 2012 | 04:46 PM
Lanny's Avatar
Lanny is on a distinguished road
All ears!
Old Oct 1, 2012 | 06:44 PM
richphotos's Avatar
Well, to smooth out the rough texture, you can either sand it, or you can get a high build primer and then sand between coats on that. But since it is plastic, You will need an adhesion promoter before you lay down any paint, or it will come off in no time.
Old Oct 1, 2012 | 08:10 PM
Search really does work if you know how to use it. Heck, there is even a tech article on this very topic.
Old Nov 22, 2013 | 04:01 PM
JBlaze2K's Avatar
JBlaze2K is on a distinguished road
i have the same problem, and have trim in great shape from another blazer, can anyone tell me how to actually remove those back windows?
its much easier for me to remove and replace the entire trim and window than to tape off, fill, sand, primer, sand and paint. how in the hell to i get em off of there lol
Old Nov 25, 2013 | 06:14 PM
Dark Rider's Avatar
Dark Rider is on a distinguished road
Again, to what swart said, use the search feature. I posted this a couple weeks ago on a quick repair to the rear window trim. Would'a/should'a popped up at the top of the search results.
As for taking it off and replacing it, your looking at hundreds of dollars as the trim is connected to that rear window... So unless you wanna replace the entire window for the trim's sake, it looks like you're stuck painting it.
Old Nov 25, 2013 | 07:23 PM
CAB's Avatar
CAB
CAB is on a distinguished road
blazerguy22
Mar 30, 2019 09:47 AM
okvortec
Dec 6, 2010 10:29 AM
okvortec
Dec 8, 2009 06:25 AM
blazerguy22
Oct 13, 2009 02:54 PM
brunosrk
Nov 18, 2007 10:21 PM
