Remove the instrument panel accessory trim plate
Old May 31, 2011 | 03:48 PM
hace1's Avatar
hace1 is on a distinguished road
Default Remove the instrument panel accessory trim plate
Hello i need some help, my instrument cluster lens is broken and i must replace it but how do i remove the instrument panel accessory trim plate?
The car is a Blazer 1998
Old May 31, 2011 | 03:55 PM
dimone545's Avatar
dimone545 is an unknown quantity at this point
If your talking about the bezel that wraps all the way around the front of the dash it just pops off bro. I just pull it off with my fingers, there are little clips that hold it on there.
Old May 30, 2012 | 11:34 AM
darklink's Avatar
darklink is on a distinguished road
The trim plate does pull off pretty easy as it is mostly clips that hold it in but there are 2 screws that hold it on both sides of the steering wheel. There should be 4 screws on the panel below the steering wheel. Take those out and pop that piece down. You will then see the 2 screws retaining the trim plate on the sides of the steering wheel.
The other issue is that you need put the vehicle in D1 or when you go to pull the plate out it will snag on the shifter.
dannyb91979
Feb 24, 2012 09:17 AM
blazin4eva
Dec 17, 2009 08:22 AM
trettifire
Oct 3, 2009 08:48 PM
recruiter
Jan 5, 2007 02:58 PM
jack
Aug 8, 2006 02:38 AM
