Remove the instrument panel accessory trim plate
Hello i need some help, my instrument cluster lens is broken and i must replace it but how do i remove the instrument panel accessory trim plate?
The car is a Blazer 1998
The trim plate does pull off pretty easy as it is mostly clips that hold it in but there are 2 screws that hold it on both sides of the steering wheel. There should be 4 screws on the panel below the steering wheel. Take those out and pop that piece down. You will then see the 2 screws retaining the trim plate on the sides of the steering wheel.
The other issue is that you need put the vehicle in D1 or when you go to pull the plate out it will snag on the shifter.
dannyb91979
Feb 24, 2012 09:17 AM
blazin4eva
Dec 17, 2009 08:22 AM
trettifire
Oct 3, 2009 08:48 PM
New problems: Headlights flicker, instrument panel lights up with buzz and engine quits while cruise
recruiter
Jan 5, 2007 02:58 PM
