Replacing door pins
Old Oct 26, 2010 | 08:31 PM
DaveHearne's Avatar
DaveHearne is on a distinguished road
Default Replacing door pins
Hi, I need to replace my drivers door pins & bushings as the door has dropped badly. What I want to ask is has anyone managed to get this job done without disconnecting the electrics? I was wondering whether I would get away with protecting the door with an old bedsheet & hanging it from a beam in my garage so that I can remove the pins then just pull the door far enough out to be able to access the bushes to replace them. Is the wiring long enough to be able to do this? I have a tool to remove the spring so that is no problem. I figured this would save me a lot of time if I didn't have to pull the door panel off to disconnect the electrics.
Any advice would be appreciated.
I was over in the USA a couple weeks ago & I bought the pin & bush kits from Advance Auto Parts as they are much cheaper than here in the UK, so I have everything I need to start the job - would just appreciate a bit of advice first.
Old Oct 26, 2010 | 08:45 PM
AJBert's Avatar
I didn't disconnect the wires when I did mine. I used one of the kitchen chairs with a couple of pillows so it sat at just the right height. An extra pair of hands comes in mighty hand, also.
Old Oct 26, 2010 | 10:16 PM
abig84's Avatar
its best if someone can help. i always got the top one out first then stuck a screw driver into the hinge to hold the door into place then do the bottom one
Old Oct 26, 2010 | 10:17 PM
DaveHearne's Avatar
Thanks for the reply - that should save me a lot of work.
I will have a go at it this afternoon & enlist the help of someone. My door has dropped so badly that rain sometimes gets in when i'm parked up. Can't find anything wrong with the rubber seals so I am assuming that it's because the door is sitting too low & not contacting the rubber properly in places. I think if I leave the job much longer the pins will wear what's left of the bushes away & start eating into the hinge itself - then i'll be in trouble.
Old Oct 27, 2010 | 07:18 AM
Extra hands make it a lot easier, but if you have rafters you can tie off on, you should be able to get it done quite easily by yourself. Don't pull the electrical conduit too tight and you should be ok there as well.
Old Apr 3, 2011 | 09:44 AM
ronaldo's Avatar
ronaldo is an unknown quantity at this point
Default Helps to put tape along where the fender and door panels meet
Even with extra hands it is easy to grind these two areas together and mess up the paint a little bit.
n0thing43
Feb 15, 2011 06:18 AM
Nemo1991
Jul 5, 2010 01:07 AM
BlazEnvoy
Feb 14, 2008 05:01 PM
tammikm
Dec 3, 2007 02:26 PM
Xtreme Blizz
Aug 11, 2007 10:50 AM
