Replacing mirrors
Old Jul 31, 2007 | 09:01 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default Replacing mirrors
How do youreplace the side mirrors? I'm thinking about ordering new side mirrors, but I want to at least have a base knowledge so I know what I'm getting into.
Old Jul 31, 2007 | 09:21 PM
rriddle3's Avatar
Default RE: Replacing mirrors
Here ya go.
Mirror Replacement
Removal Procedure
Remove the door trim panel.
[IMG]local://upfiles/4800/79A05FE0FE6D46F6BB3E30CDE93FD72C.gif[/IMG]
Remove the access hole plugs.
Remove the nuts that retain the outside rearview mirror to the door.
[IMG]local://upfiles/4800/57FEB937193D443290679B540FB0D171.gif[/IMG]
Remove the outside rearview mirror from the door.
Disconnect the electrical connector, if equipped.
Installation Procedure
[IMG]local://upfiles/4800/D018D8E5321F445783FA4573672ECCB8.gif[/IMG]
Connect the electrical connector, if equipped.
Install the outside rearview mirror to the door.
Notice
Use the correct fastener in the correct location. Replacement fasteners must
be the correct part number for that application. Fasteners requiring
replacement or fasteners requiring the use of thread locking compound or
sealant are identified in the service procedure. Do not use paints,
lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces
unless specified. These coatings affect fastener torque and joint clamping
force and may damage the fastener. Use the correct tightening sequence and
specifications when installing fasteners in order to avoid damage to parts and
systems.
Install the nuts that retain the outside rearview mirror to the door. Tighten
Tighten the nuts to 6 N·m (53 lb in).
[IMG]local://upfiles/4800/1828C5BB66C34946B3D6F8B30003F1C4.gif[/IMG]
Install the access hole plugs.
Install the door trim panel.
Old Jul 31, 2007 | 09:31 PM
EuroGoldLS's Avatar
Thanks man!!
Old Jul 31, 2007 | 09:33 PM
rriddle3's Avatar
Glad to help whenI can.
fresno99
Jul 31, 2009 08:12 PM
timetoblaze
Apr 11, 2005 10:08 PM
BlazeDaddy
Apr 11, 2005 05:30 PM
02 Vortech
Mar 22, 2005 12:16 AM
IlonewolfI
May 27, 2004 12:13 AM
