rust issue
Old Apr 12, 2011 | 07:29 PM
RMBlazernut's Avatar
RMBlazernut is on a distinguished road
Default rust issue
ok my blazer project is going to be a little tougher than i thought. i need opinions on how i should go about fixing this..this is the only bad spot on the truck other than the rocker panels..would you glass it in or what..i want something that's going to hold up in Michigan winter..i would cut it out andadd a new piece but i dont have access to a welder..here are some pics.
all you body experts please chime in..
thanks for your input in advance
Rick
Old Apr 12, 2011 | 08:42 PM
warthogdriver's Avatar
ok i am no expert by any means.
i had a spot like that but only 7" or so long.
now i have my rockers and wheel wells covered in bed liner anyway so.
i cut out the bad about 1" past on either side and than got a piece of steel stock 1" wide or so and then bought the reinforced fiberglass filler and rebuilt it.
i bent the steel to match the well curve and fastened it to the good portions of panel with self tappers. now i do have a welder but i figured my luck i would warp the panel or burn it up....so i settled.
the first layers or so i went heavy on hardener to have set quick so it would stay in place. i then built on that and shaped as i went.
i basically have a 7" long chunk of fiberglass in the middle of the wheel well. been that way since last fall no problems.
prob not the best way but its working.
Old Apr 12, 2011 | 08:51 PM
thats what i was thinking....just didnt know if fiberglass would hold up in the winter
Thanks for your input
Rick
Old Apr 12, 2011 | 08:59 PM
Zanders's Avatar
Zanders is on a distinguished road
you shouldn't be worried about a repair job as stated above^ in winter. I live in the snow belt too, just make sure its all sealed up and a fresh layer of clear coat on it.
Chic_Bowdrie
Mar 31, 2012 08:47 AM
yeags
Detailing
Dec 7, 2006 02:00 PM
mistasmiff
Detailing
Aug 30, 2006 11:57 PM
docmoody
Aug 15, 2006 10:13 AM
BlazerSquad93
Headers, Intake, & Exhaust
Mar 4, 2005 11:25 PM
