AT shifter boot
Old Apr 22, 2007 | 06:11 PM
Marcin's Avatar
Marcin is an unknown quantity at this point
Default AT shifter boot
Hi
Could tell me the name of part I need to replace. It is something like gear shifter boot for AT shifter located on steering column. It is not true boot but something like seal and it is made with gum. My old one is broken and I would like to replace it but can not find at any internet shop. Any idea how to find it?
Marcin
Old Apr 22, 2007 | 07:28 PM
hockeykid15's Avatar
hockeykid15 is an unknown quantity at this point
Default RE: AT shifter boot
it is called the "shift rod seal" i tried to find a link for you but cant find a site that has one. i would try going to your local dealer. they will be your best bet.
Old Apr 22, 2007 | 07:33 PM
Marcin's Avatar
Thanks a lot for the part name!!! But in Poland there is no dealer for US Chevy
Marcin
Old Apr 22, 2007 | 07:42 PM
well in that case... if you bought the car from a dealer try going there and see if they can order one for you. you could also try contacting a u.s. dealer and see if they will send one. other wise, since it does not directly effect the car, i would leave it alone.
Old Apr 22, 2007 | 07:55 PM
Marcin's Avatar
Is it this part number 20 : http://tinyurl.com/2mu4g2 ?
Marcin
Old Apr 22, 2007 | 08:11 PM
yes i believe that is it. if you look at yours i think it is just a rubber peice that should pull out. that way you can compare the backs to make sure it is right
matthewp
Apr 4, 2021 09:16 PM
jasedude
Nov 24, 2010 04:03 PM
rbcar1
Dec 13, 2009 10:20 AM
RCars2
Suspension Tech
Jul 20, 2007 12:08 PM
beecherr345
Apr 26, 2007 08:41 PM
