Tahoe Tow Hooks dont fit.
Old Sep 4, 2012 | 06:35 PM
dustinhxc's Avatar
dustinhxc is on a distinguished road
Default Tahoe Tow Hooks dont fit.
So I read on here from a couple people that 90s tahoe tow hooks are a direct fit so I ordered a pair on ebay. Well I just tried to put them in and the holes/bolts are larger than my jimmy holes/bolts so they wont even screw through the frame. Anyone have experience using tahoe tow hooks? Thanks
Old Sep 4, 2012 | 07:21 PM
dustinhxc's Avatar
I think I will just use the same width as the stock bolts. But I will get longer ones, then just get a strong nut for the end of each one. So the towhooks will have play around the bolts since they are meant for the wider bolts. But the nut should hold them in fine and the bolts will obviously be threaded through the frame since its factory width Ill be using..
Old Sep 4, 2012 | 10:55 PM
abig84's Avatar
if there the same ones im thinking of i have used them on a few s10s... but in the back. you may be able to drill a hole in the hooks in order to get the bolt holes to line up
heres one i had on the back of a 85. it ripped the frame in half trying to pull out a H2. Tow hook was fine
Old Sep 5, 2012 | 10:25 AM
rexmburns's Avatar
Super Moderator
Since the frame holes arent threaded couldn't you just drill the frame out a little bit more to accept the larger bolt from the larger tow hooks? I think that would be the better way to go that way the hook is being secured as it was intended by Chevy when they designed them.
willjones
Lifting Tech
14
Mar 31, 2008 04:14 PM
blazer123456789
Jan 13, 2007 10:33 PM
BlaZeR FXB1581
Jul 31, 2006 02:23 PM
vspeers1
Jun 3, 2006 10:51 PM
blazerscooby
Mar 3, 2006 02:01 AM
