Tail Pan Repair
Old Feb 24, 2009 | 07:24 PM
oisinirish's Avatar
Default Tail Pan Repair
So i've cut out the rust and refab'd the rusted part of the pan. Should I do more than prime and paint the pan before puting the bed floor back over it?
Old Feb 24, 2009 | 08:11 PM
Default RE: Tail Pan Repair
I would spray some weld through primer on it before you weld in the to part. Then use some seam sealer on the underside to seal up the repaired area.
Old Feb 24, 2009 | 08:41 PM
oisinirish's Avatar
An observation....I'm not sure if all the 80's K5's are the same but when I cut the tailgate post in the void for the tail light wires there was a large amount of what feels like carpet pad material. Probably holds moisture and helps rust.
ooohoooh another quickie....do welds usually rust through? There is a factory spot weld that I have ground half way through the steel and the weld still show rust.
Old Feb 25, 2009 | 01:26 PM
I do not remember anything being inside the tailgate post on my K5 when I was under there poking around. It could just be sound deadener or something a mouse pulled up in there to make a nice home...
As far as factory spot welds rusting through... Typically it is the surrounding metal that rusts away, leaving the actual spot weld...
Old Feb 26, 2009 | 02:59 PM
oisinirish's Avatar
You think we should combine this with the Floor Panel Replacement thread....seeing as they're all part of the same project?
Old Feb 26, 2009 | 03:47 PM
Probably. Just leave this one alone and use the other one.
sidviscious
Oct 8, 2009 08:38 PM
LoLoS10Blazer87
May 28, 2006 09:11 PM
blazingsadle
Apr 10, 2006 05:50 PM
swartlkk
13
Dec 20, 2005 08:13 AM
enrybwerd
Oct 9, 2005 12:29 AM
