Time for interior upgrades
I can't remember if I bought the neons from Advance Auto Parts or Autozone, but it was definitely one of those 2. Since you mentioned adding a tachometer, I am guessing your gauge cluster does not have one right? Then if you don't have a tachometer, those gauges that I showed you will not fit, and neither will the billet trim ring. However, StylinTrucks does have a guage face for blazers that only came with a speedometer.
i found the kit i need but it dosnt show the right onein the picture i have the on like yours with the tac is it still the right one? also is there a way i dont have to use that dimmer switch that the kit comes with? thanks
i found the kit i need but it dosnt show the right one in the picture i have the on like yours with the tac is it still the right one? also is there a way i dont have to use that dimmer switch that the kit comes with? thanks
Here is the link to the page for my gauges. click here
You would probably have to splice the wires, find out which one is for the color change, and wire it into a switch below the dimmer switch. I just installed the switch under the dash out of sight. I really don't change the color at all, so I just put it there because I didn't want to mess around by cutting wires and stuff. I found this. It is for a 95 with the tach from procarparts.com off of yahoo shopping which is how I found mine.
http://procarparts.stores.yahoo.net/chs195witaat.html
ddog800
14
Feb 16, 2011 03:01 PM
truesmack
Apr 7, 2009 06:48 PM
lt170chevelle
Nov 1, 2008 08:32 PM
paulbaby
Aug 19, 2008 08:28 PM
