window seals
Old Feb 24, 2007 | 01:22 AM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
Default window seals
so anyone replaced the weather stripping around the back side door? I am looking at doing it...and wondering how hard it is...dosen't seem too hard...
Old Feb 24, 2007 | 01:37 AM
Chevy Lover's Avatar
Default RE: window seals
[ol]Open the rear side door window.
Remove the rear side door window weatherstrip.
Start the at butt joint and pull the weatherstrip from the window opening
Install the rear side door weatherstrip.
Locate the butt joint at the bottom center of the window opening and set the weatherstrip around the window opening
[/ol]
[IMG]local://upfiles/2910/197B7CB9F65B4226B61553F7DE6025E2.gif[/IMG]
Old Feb 24, 2007 | 01:56 AM
user 1016's Avatar
what about the stripping around the door itself...it's not on the door...it's the black strip around the door....just pull up and re stick new ones?
Old Feb 24, 2007 | 02:01 AM
Same idea.
[ol]Remove the door opening weatherstrip from the door opening.
Gently pull the weatherstrip from the pinch weld flange.
[ol]Install the door opening weatherstrip to the door opening.
Position the pre-formed corner of the weatherstrip in the upper rear corner of the door opening.
Push the weatherstrip onto the pinch weld flange.
Start at the pre-formed corner and work around the entire edge of the door opening.[/ol][/ol]
Old Feb 24, 2007 | 02:04 AM
davtak's Avatar
I know I asked this before, but I can't find the post. If I replace the weatherseal around the window, would that eliminate that annoying chirping noise while I'm driving. It only does it in cold weather though which is weird.
Old Feb 24, 2007 | 02:09 AM
davtak, are the seals hard? I would try applying a silicone rubber grease to try to soften and revitalize the rubber before replacing the seal.
There are also silicone sprays to keep the rubber soft.
Old Feb 24, 2007 | 02:15 AM
davtak's Avatar
I'll check. If they are, I'll give it a shot. Oh, and I found the post, and no it's not your pet budgie!
Old Feb 24, 2007 | 10:01 AM
hoop85's Avatar
hoop85 is an unknown quantity at this point
Pretty simple(for a '85) don't know about your year but should be the same just take your time.
00chevblazer
Mar 8, 2013 10:00 PM
bertrenolds
Nov 7, 2012 03:05 PM
curse
May 14, 2008 06:20 AM
kerander
Feb 14, 2008 03:41 PM
Mapoftazifosho
Oct 26, 2007 10:26 AM
