WOOHOO! PROJECTORS!!!!
Old Feb 8, 2007 | 10:42 PM
speeddemon560's Avatar
speeddemon560 is an unknown quantity at this point
Default RE: WOOHOO! PROJECTORS!!!!
Now Rabbit, you said you spliced wires to hook up the halo, but this is what someone else told me they did. "They pretty much just plug and play if y ou know what I mean. The halo is the only two wires that don’t fit your factory harness so I checked the polarity (+or-) and then lined the wires up on each side of the small amber bulb on the corner and then pushed the bulb into the socket and it holds the wires in place. Automatically as soon as my lights come on high or low the halo comes on because its connected to the corner bulb. " It sounds much easier than splicin' and dicin'.
Old Feb 8, 2007 | 10:43 PM
rabbit0102030's Avatar
rabbit0102030 is an unknown quantity at this point
Yeah, once you take your stock low beam bulb out, you plug your wiring harness into the provided (already installed) plug and LET THERE BE LIGHT!
Old Feb 8, 2007 | 10:45 PM
drperry's Avatar
ORIGINAL: rabbit0102030
Is the low beam bulb itself changeable? Might be able to swap it out for a better quality one, lol.
Old Feb 8, 2007 | 10:46 PM
Now these look sick.
Halos 1
Halos 2
Different truck with halos with a HID kit. Don't worry about the captions in the pics.
Halos 3
Halos 4
Halos 5
Old Feb 8, 2007 | 10:48 PM
ORIGINAL: speeddemon560
I dont reccomend doing it that way. One reason: I did exactly that first off and it blew my Left Headlamp fuse, the splice was very easy, clip, strip, and pinch. Took about 15 seconds each side. Another reason is the seal between the housing and bulb will have the two wires running through them allowing humidity into the headlamps, not to menion the unsightly wires you can see running out of the bulb socket from inside the housing. Then again that may just have been the case on my truck.
Old Feb 8, 2007 | 10:51 PM
drperry's Avatar
Not to mention it's a potential fire hazzard, because it's not a secure connection, and if the fuse keeps blowing, chances are, most people do it the lazy way and just get a bigger fuse...
Plus, it's fugly having wires coming out of a bulb socket, lol.
Old Feb 9, 2007 | 01:18 AM
iceflames11's Avatar
iceflames11 is on a distinguished road
Speeddemon, the links dont work. They go to some google site that needs a username and password.
Old Feb 9, 2007 | 07:45 AM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
SpeeedDemon, its giving us a GMAIL link instead of pics.
Rabbit, what price range did these fall in? We found some on ebay for 125 shipped I think and I think I looked up more that cost more and were more shipping for the same item. So we arent sure. he found a plug and plug HID conversion but im wary of the heat they produce. I wouldnt mind finding em for his bday but I just need help finding a decent set.
Old Feb 9, 2007 | 10:12 AM
ORIGINAL: DetroitMuscle
They were $136 shipped. This is good set in my opinion, because you can pull them apart and add your own features (like I'm going to be doing.) I want to add a set of strobes and switch it over to HID. The particular set I got is going to allow me to do this without damaging the assembly. You just have to look and always ask questions. I never buy anything until I have been disclosed all the info I think I need. The more questions you ask the sellers the better product (and closer to what you're looking for) your gonna get.
Old Feb 9, 2007 | 03:28 PM
drperry's Avatar
Indeed, and the projector housing is removable, according to the seller, lol, which makes a proper HID conversion much, much easier, and cleaner looking!
CraigSnedeker
Oct 6, 2009 07:35 PM
scottyk
Feb 27, 2007 11:51 PM
TheDesertFox
Oct 3, 2006 06:24 PM
LittleDan911
Jan 22, 2006 10:52 AM
m00nwater
Aug 5, 2005 12:40 PM
