Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
1988 s10 blazer with a 2.8 hp improvements?
Old Mar 18, 2011 | 04:14 PM
luckyferg1313's Avatar
luckyferg1313 is on a distinguished road
Default 1988 s10 blazer with a 2.8 hp improvements?
i need some hp increase ideas for my blazer i mean it will light up the 33/10.50 BFG ATs its got on it but i want some more ppower and i plus to get it dirty but thats a different section so i wont bother with the mud. but please help me with the ideas. i've already put a kn filter in it but that's just to help her breathe a little easier. i look forward to the help guys
Old Mar 18, 2011 | 06:15 PM
rriddle3's Avatar
Honestly, there's very little you can do to a 2.8 without spending so much money as to be completely impractical. They jsut were not designed with that in mind and the aftermarket for performance parts is extremely limited. If you want to be able to use the transmission that's in it now, you could take a 3.4 that was used in Camaros and Firebirds from the same time period and swap it in since it will mate up to the tranny.
Old Mar 18, 2011 | 07:49 PM
neo71665's Avatar
Being as these are pretty popular in sprint car classes there are tons of parts out there, there is even a cult following with them in the fiero crowd. I laugh when I see anybody say that. Just because the engine isn't as popular as the 4.3 doesn't mean the aftermarket doesn't support it. Anything you can find for a 4.3 I bet I can just as easily find for a 2.8, from turbo and supercharger kits down to simple roller rocker arms and cams. I really wish people would stop giving out false info on engines for whatever reason. If you don't understand them or know about them thats fine just state so.
While I do agree I wouldn't spend much time inside the engine on better parts all the aftermarket parts like roller rockers and headers work on the 3.4 also. I would really look into swapping in a 3.4 out of a camaro first. You get all the HP the 4.3s had but they are lighter and tend to be better on gas then the bigger v6. If you just want to keep the 2.8 I would have the intake bored out to take the 4.3/v8 throttle body. You can then look into roller rockers and a cam. I know comp cams makes cam kits for them.
You can always check out the links here
1993 GMC Sonoma / 1990 Isuzu Trooper
And this site is more friendly on the 60 degree
60DegreeV6.com - Site News
Old Mar 18, 2011 | 10:28 PM
thanks guys i appreciate the ideas i don't really have the time or money for an engine swap. how much of an increase will a throttle body spacer give me. i've already put a glasspack and a k&n air filter on her how do you flip the lid on the air cleaner? it doesn't close all th way does it help or hurt.
Old Mar 19, 2011 | 07:21 AM
atvwarrior's Avatar
atvwarrior will become famous soon enough
If you plan on going through mudd I would not flip the air cleaner , thats just asking for trouble .
Old Mar 19, 2011 | 07:13 PM
neo71665's Avatar
A spacer is pointless on a 2.8, the intake doesn't need it. Matter of fact they about the same on a 4.3 as the intakes have more than enough room in them from the factory. I run an open cleaner with a K&N on mine and mud bog it. I have a prefilter I put on it when I get dirty that wraps around it but over all I've never had much of a problem. Just try to keep as much crap out of it as you can. Truth be known I sucked up more water when the factory snorkel was hooked up to the core support than I ever do now with mine looking like this.
musclemasterflex
Aug 25, 2011 09:22 PM
djramsay
Jan 11, 2010 12:42 PM
djramsay
Apr 10, 2009 09:30 PM
95LS
May 6, 2008 09:31 AM
houdini_dan
Apr 19, 2008 04:12 PM
