Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
305 sbc into 96 4x4 blazer
Old Sep 4, 2011 | 04:28 PM
CenTexBiker's Avatar
CenTexBiker is on a distinguished road
had thought about that
but
with being able to get a 305 and ecm for free from family
I thought it would be a great way to get the power I wanted without some of the cost that I would have otherwise. besides I would rather have a tbi system than the spider system
Old Sep 4, 2011 | 04:29 PM
TheRandom1's Avatar
You'd also need the wiring harness, motor mounts, other such adapters, etc. I imagine for what you'd spend in swap parts, you could rebuild your V6 with a couple performance parts and easily get the power you would out of a stock 305.
What is the 305 out of?
Old Sep 4, 2011 | 05:02 PM
the 305 is out of a 91 c1500
Old Sep 4, 2011 | 05:03 PM
as to wiring harness. are you referring to the one from the firewall to the engine?
Old Sep 4, 2011 | 05:11 PM
TheRandom1's Avatar
Yup, the one that will power the engine, ecm, etc. You may need to repin it to plug correctly into your body harness, assuming they are the same plug.
If I'm not mistaken, that engine only makes about 175 HP. Your stock motor should make 190 HP. So you're adding weight and losing power with a stock motor the route you're looking at. Doesn't make any sense to me.
Old Sep 4, 2011 | 05:14 PM
tibby's Avatar
Default .
The other thing is looking at the age of both motors. Unless you are going to rebuild the '91 motor, it probably wouldn't be worth it.
Old Sep 4, 2011 | 05:25 PM
you guys are awesome. I am glad that there are people out there like you that are willing to help a stranger
the 305 is a recently rebuilt with all the goodies installed
Old Sep 4, 2011 | 05:27 PM
TheRandom1's Avatar
Has it been dyno tested?
Old Sep 4, 2011 | 05:34 PM
from what I was told I puts out 300hp and 350 torque
dont know if those numbers are true tho
can a 305 put those numbers out?
Old Sep 4, 2011 | 05:35 PM
TheRandom1's Avatar
"Can it?" Sure. Anything can do it. Reliably is the issue, and I don't know if I'd trust a 305 to do that as a DD.
