Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
95vs96+ heads?
Old Aug 10, 2013 | 11:32 AM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Default 95vs96+ heads?
Ok so I havent gotten a straight answer yet... Will 96+ vortec heads fit on a 95 block? I am just wondering so that I can do a marine intake mod on a 95, because I know the marine intake wont line up with 95 or later heads. So now I'm just wondering if heads are interchangeable so that I can put the marine intake on. I know I'll need a different computer since its a cpi motor. Thanks for the help!!
Old Aug 12, 2013 | 07:42 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
the 96 heads will bolt onto the block, just the stock 95 intake manifold wont bolt to the heads.
Old Aug 13, 2013 | 07:56 AM
Crackers's Avatar
Crackers is on a distinguished road
Isn't the difference just the angle of the bolt holes though? (At least as far as interchange comparability anyway?)
I know when the corvettes came out with the TPI injection they changed the manifold bolt holes from perpendicular to the mating surface on the head to straight up and down for clearance.
We used to use the stock aluminum intake off a late 80's Camaro on our 70 Chevelle race car, we just opened up the holes with a die grinder to make them work. If I were to do it again today, I'd drop the manifold at a welder with a TIG to have them weld the bolt holes solid and re-drill the holes. (We had to run factory GM parts in our division. The newer manifolds did perform better, but we did it primarily for weight.)
I really like the look of the older cast AL plenum, I'd like to find a way to make it work with the newer heads.
Old Aug 13, 2013 | 09:41 AM
I plan on doing a marine intake on the 95 block and I know it wont fit on the 95 heads, so I'll have to get 96 or newer heads to fit so that the marine intake will fit... Right?
Old Aug 13, 2013 | 09:51 AM
that is correct
Old Aug 13, 2013 | 01:45 PM
Awesome just what I needed to know! Now how about turbos on these motors? I know alot is vacuum controlled, will a turbo greatly effect these systems?
Katmandu
Dec 27, 2024 12:04 PM
Licklog
Nov 1, 2009 01:09 AM
Slow Rollin
Feb 9, 2008 08:00 PM
Blazin_Jason
Engine & Internal
Feb 28, 2007 10:40 AM
steiner_5000
Feb 13, 2006 02:51 PM
