Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
96 - 98+ brake swap?
Old Jun 12, 2014 | 07:10 PM
guitar134's Avatar
guitar134 is on a distinguished road
Default 96 - 98+ brake swap?
Digging around on the computer at work, i noticed the brakes on the later models seem alot beefier and there are more pad options availible. so i was wondering if a swap was possible?
is it just a knuckle swap? or is there alot more invloved?
Old Jun 13, 2014 | 10:25 AM
El_Beautor's Avatar
To do the swap you need the newer style knuckle/spindle (don't really know the proper name. The triangle shaped kajigger where the ball joints and the tie-rods mount), the newer rotor and the newer caliper and pads. You should be able to reuse your hubs, however it would be a good opportunity to move to the newer style hub too if you want to replace those as well.
Old Jun 13, 2014 | 07:43 PM
guitar134's Avatar
thats what it looked like. ill see what the local jy has and maybe make a small wright up on it if i get around to do it.
Old Jun 14, 2014 | 01:04 AM
LeWhite's Avatar
It's a good mod, especially if you have bigger rolling stock.
Old Jun 15, 2014 | 07:21 PM
guitar134's Avatar
right now the wife drives the truck as a DD, once we buy her a new car ill start to mod it up and look at the upgrade. i just put new pads on it and saw the design. seems a little weak for the corrosion we see here in the salt lands of the north.
Old Jun 15, 2014 | 08:34 PM
LeWhite's Avatar
What do you have on the rear?
Old Jun 23, 2014 | 08:17 AM
guitar134's Avatar
its drum, i actually like drum brakes. but when i lift it and throw tires on it i will probably find a disc rear end at a yard and pull everything. on the ford forums there is a rear disc swap that calls for changing the proportioning valves, however if you leave the drum valve in youll get a little more rear brake action. i'd assume its the same story on 90% of the brake systems out there.so based on assumtion ill probably use this to my advantage with the larger tires
chevyblazer
Jun 20, 2014 12:32 PM
chevyblazer
May 22, 2014 03:15 AM
step66
Jan 12, 2013 10:51 AM
reagor
Apr 4, 2010 02:48 PM
eelding
May 2, 2007 12:54 AM
