Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
airbox mod..
Old Apr 1, 2008 | 05:51 PM
cliro's Avatar
cliro is an unknown quantity at this point
Default airbox mod..
I was bored at work today and decided i'd try the airbox mod, cut out the front and put some 3/4" holes in the side. wasn't expected much of a differance but damn, my exhaust setup sounds sooo.. much better now when I tromp on it. hehe..
I actually thought it was going to sound like crap and use it as an excuse to buy a FIPK... but ..I like it.
Old Apr 1, 2008 | 05:54 PM
TripleBlackBlazer's Avatar
Default RE: airbox mod..
If it is what I'm imagining it to be, you're also sucking in hot air from the engine bay now too. May want to shield that bad boy up!
Old Apr 1, 2008 | 06:22 PM
cliro's Avatar
i only cut in the front where the tube was and the fender side, so it shouldnt be that bad, all sides against the engine are still shielded.
Old Apr 1, 2008 | 07:15 PM
fla_blazer4x4's Avatar
fla_blazer4x4 is an unknown quantity at this point
have anypics? i did the same thing, to mine took out the tube with the rivits so much better when im throttleing it.
Old Apr 1, 2008 | 07:21 PM
Made it louder is about all you've done. I'm betting that you'll notice a 30-50*F rise in IAT readings.
Old Apr 1, 2008 | 09:50 PM
cliro's Avatar
I can't see how it would be that much warmer, the part thats cutout is just the front and side which sits directly behind the headlight andby the windshield washer reservoir, and its just the bottom section of the airbox. An air intake even with a shield still has more exposed filter then this setup.
Old Apr 2, 2008 | 12:10 AM
94blueknight's Avatar
94blueknight is on a distinguished road
so u swiss cheezed ur airbox hmm ya never was a fan of that. i wonder what the numbers tell u. i would just do the homemade cai (i plan to do so in summer)
Old Apr 2, 2008 | 05:33 AM
Even an out of the box K&N FIPK has shown to have IATs higher than the stock airbox. Unless you seal the area, you will see higher IAT readings which isn't good. The impact will be higher the higher the outside temperature.
By removing the tube, you have opened the airbox up to draw air from closer to it instead of just through that hole behind the headlight. If this area were directly open to the front of the truck, you wouldn't be as bad off, but with the headlight in front of it...
Without a scan tool you'll never know.
Old Apr 2, 2008 | 08:19 AM
cliro's Avatar
ah well it sounds good!!
IanD
Jan 27, 2013 02:40 PM
chris015
Engine & Internal
Jul 2, 2012 01:04 PM
kgkern01
Headers, Intake, & Exhaust
14
Jul 16, 2011 02:15 AM
Blazerboy1611
Feb 25, 2010 11:38 PM
jynxK5
Feb 15, 2009 03:55 PM
