Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
Brainstrom cause my rear main seal going out
Old Dec 2, 2008 | 07:21 PM
bigjoeblaze's Avatar
bigjoeblaze is an unknown quantity at this point
Default Brainstrom cause my rear main seal going out
I have been thinking alot since my rear main seal is going out is to convert my 4x4 to 2wd and do a 350 swap. i always wanted more power and i dont use my 4x4 and think about lowering the blazer.Does anyone got any suggestion on what to do? Does anyone know if u can swap out the 4x4 for a 2wd?
Old Dec 2, 2008 | 07:26 PM
Default RE: Brainstrom cause my rear main seal going out
You can remove the parts, however, you would need to get a 2wd transmission to complete the change over. You could always keep your 4wd system and drop in the 350.
Old Dec 6, 2008 | 07:37 PM
Blzr01Gy's Avatar
Blzr01Gy is an unknown quantity at this point
Thenew 350 is obviously much heavier than the 4.3, so typically you need to beef up the front end a little bit to make up for the extra weightand change your pinion angle and a fewother things. But look around for a front suspension lowering kit for a 350 swap. I had a few buddys do that with theirs
Old Dec 6, 2008 | 07:44 PM
Change the pinion angle...? While you may need to crank the t-bars (since he has a 4wd), that is typically it. The front suspension can handle the added weight.
Old Dec 6, 2008 | 09:39 PM
Blzr01Gy's Avatar
its what i was told. sounded weird to me too
Old Dec 6, 2008 | 11:52 PM
When you lower it, you may have to change the pinion angle, but that all depends. I thought you were saying that about the v8 swap...
Old Dec 7, 2008 | 12:48 AM
Blzr01Gy's Avatar
Yeah he said he wanted to lower it with the v8. I was gonna swap mine awhile back with a 350 just never got around to it and ended up selling the motor
ebristol
Apr 1, 2008 04:53 PM
piggyb00
Feb 6, 2008 08:46 AM
MikeD
Engine & Internal
Mar 3, 2007 11:24 PM
FImports
Dec 13, 2006 03:00 PM
smitty
Aug 12, 2005 11:38 PM
