Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
Comp Cams
Old Jul 12, 2013 | 06:41 PM
01blazer16's Avatar
01blazer16 is on a distinguished road
Default Comp Cams
What will be changed if I put comp cams in my truck?
Old Jul 16, 2013 | 05:51 PM
94_FoeDoe's Avatar
94_FoeDoe is on a distinguished road
Default cam change
Your exhaust gas ratio will change dramatically and the engine will not run correctly. Also, the MAF on the intake sensor will have to be re-calibrated, you would have to run 93 octane gas, change spark plugs to V-8 ones. Transmission would have to recalibrated. Power steering fluid would have to be changed to Dexron 6. Motor oil changed to 90W gear oil. Rally lots of changes needed
Old Jul 16, 2013 | 06:59 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Depends on the duration and lift and it has to be computer compatible.You have a roller cam its going to be very expensive to change it.If you have the $500 go for it.
Zerbla96
Engine & Internal
Feb 24, 2010 11:41 PM
jsmz
Lifting Tech
Dec 25, 2009 12:23 PM
jdell1107
Tires and Wheels
May 14, 2009 08:59 AM
ChevyBoy413
Feb 13, 2008 04:22 PM
YBLegal
Engine & Internal
Mar 25, 2005 12:54 PM
