Converting to an electric fan
#21
but it takes power from the crankshaft via the belt to turn the fan why wouldnt u gain from taking it off
#22
Well 1) the belt is still turning the water pump, so still a load at the pulley, 2) the thermostatic clutch works great...on at idle, cuts off at high speeds (when you need more power) and 3) you don't gain from taking it off because the engine still has to produce the energy to provide electricity to the fan so the fan can convert the electricity back to rotational (mechanical) force.
Now if you put a giant solar panel on the hood and connected that to an e-fan (all of which have to weigh less than the stock fan/clutch assembly), thennnn you might see a minuscule boost..but you'd be SOL in the mornings trying to cool the engine with a dead fan![Big Grin](https://blazerforum.com/forum/images/smilies/biggrin.gif)
#23
didnt think about that u just put the load somewhere else, the alternator, besides i hear the roar i know its cooling
#24
Not necessarily
...I just replaced my fan clutch because I heard the roar all the way up to 3500 rpm...and I couldnt go higher if I wanted too. My fan clutch failed tight I guess...so it spun all the time, and actually interfered with cooling (and power) at highway speeds.
![Wink](https://blazerforum.com/forum/images/smilies/wink.gif)
#25
I have said this before in this thread. Power is not free. Every conversion you go through, power is lost in the process. You may be able to find an e-fan that has a more efficient blade design that can pull more air with less power, but in the end, the difference would be so negligible that you would not be able to repeatedly see any gain.
The benefit of an e-fan is you can turn it off whenever you want and not have any drag on the engine. So say, if you were to be drag racing and you just wanted it to run off while you made your pass, then command it on full afterwords.
The benefit of the thermo-clutch is that it only draws power when it senses higher heat from the radiator. A while back I had posted a video of my stopping the fan on my Bravada while the engine was running. I just stuck my hand into it with a cold engine. Now do not go out and try this, I was only proving a point that the stock clutch fan actually has very little drag on the motor when it is not engaged. It is very reliable and cheap too.
Now, as far as installing e-fans go, when installed in vehicles from the factory, they are tied into the vehicle so that they are commanded on high (in the case of two speed fans) whenever the A/C is on to handle the additional heat. They are also triggered by the temperature of the coolant. Most people just wire them in and have them sit on all the time, but have a switch to kill them when they want. If you feel like baby sitting your truck while you drive it (ie. always have to remember to turn the fans on and off at the appropriate times), then you will have a better experience. However, if you just turn them on and go, then you really are just wasting that air flow. The best way to install these setups is with a controller that ties in to a temperature sensor or probe in the coolant and turns the fans on appropriately. I think there are a few manufacturers that have these controllers and I remember reading of one that even has an input for A/C clutch sensing so it can turn the fans on whenever the A/C is on.
One last thing. I believe this has been mentioned in this thread before as well, but here goes again... The stock fan can pull a LOT of air through the radiator. Most e-fans are limited in the amount of CFM they can flow and the higher CFM rated (+1000CFM) fans are expensive. Also, if you do a lot of highway driving, you will need to modify the fan shroud a bit. As I have witnessed on quite a few e-fan converted vehicles, at highway speeds, the e-fan will actually restrict airflow through the radiator. The modification is simple. Cut bypass sections out of the shrouded area in of the e-fan frame. Back bypass holes with some rubber flaps on the engine side of the fan. When the fan is on and speeds are low, the flaps will be sucked in by the lower pressure area between the fan and the radiator, but at high speeds as pressure builds in this area, the flaps will open, relieving any restriction.
#26
my fan clutch went bad with a wobble in it so it broke the fan so when the second one broke i put in two ele fans with a relay that had a temp probe u put in the rad so i just adjusted it to come on just a hair behind the 210 mark so i only c them ever come one when in sittin in drive in a long line (mcdonalds) so i see a small gain in power and about .5 more mpg so it was easy to install twowires to the fans one too a constant and another to the power goin to the a/cas a constant not only that but it was only 20 more dollars than a new cluch and fan at autozone so i like like it
#27
stick with stock
but if your dead set on going to e-fan
why not go and get a fan from a 2001 chevy malibu
they have two 10 inch fans i believe
#28
i know when i changed my stockfan to a e fan i gain some hp and MPG the stock fan give alot of drag on the engine now it feels stronger i put 2 fans 1 ten inch and 1 fourteen inch fan only cost me 140 bucks cheap
jayfire
01-20-2012 12:16 AM
Nick_K5_Blazer
23
04-08-2011 08:36 AM
Anthrsckmnd
03-30-2011 05:52 AM
punx.inc
12-25-2007 12:07 AM
