Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
i do know if it is possible
Old Mar 15, 2009 | 03:08 PM
my's Avatar
my
my is an unknown quantity at this point
Exclamation i do know if it is possible
ok i have an idea i have had it sence i got the blazer it was to put a standerd trans in it i i dont know if it is possible or not and if it is do i have to put all new wiring in if you could let me know fast it would help i have all ready droped the trans and have another one wating to go in but if i can make a tranderd work in it i would do that thanks
Old Mar 15, 2009 | 04:51 PM
rriddle3's Avatar
I wonder what year your Blazer is? If you will create a signature with your vehicle info in it, we won't have to ask this question each time, but maybe this thread will help you. The 'search' function is your friend. It only took me about 3 minutes to locate this one.
Old Mar 15, 2009 | 06:43 PM
my's Avatar
my
sorry didnt think of that and most of the time if you start up an old forum again no one responds
Old Mar 17, 2009 | 11:37 PM
BuckingBullMan's Avatar
BuckingBullMan is on a distinguished road
The easiest way I have found to determine these type of things is to see if a standard trans was made in the same year vehicle you are working on if so then you can get all the swap parts from either a wrecking yard or the dealer hope this helps......
Old Mar 18, 2009 | 07:18 AM
Yep, really need to know what year it is you are driving. Putting that information in your signature and attaching it to your posts is a good way to keep these types of questions from being asked.
As far as doing a manual transmission swap, just as BBM has said, if it was offered in that year, you should be able to get everything to make the swap. If you have a newer truck, you will need to get the PCM reprogrammed to remove the control and diagnostic systems for the transmission. If it is 4wd, then you will have to get your parts from another 4wd. I am sure there is more...
bassson
Dec 3, 2013 11:51 PM
CBlazer99
Feb 2, 2010 10:18 PM
livlifes2short
Mar 13, 2009 11:26 PM
Blazian
Apr 23, 2007 09:59 AM
LowRidinBlazer
Suspension Tech
Aug 29, 2005 10:51 PM
