Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
need help choosing parts/brands
Old Jul 23, 2010 | 08:10 PM
Project_95_Blazer's Avatar
Project_95_Blazer is on a distinguished road
Default need help choosing parts/brands
next week im doing a tuneup on the blazer i picked up and it hasnt moved really since i got it. what plugs/wires do you recommend? also what brands of CAI do you know of, any clearance issues or anything like that?also replacing the cap and rotor, fuel filter, and a few other small odds and ends. should i go with factory replacements or are there better company's? and lastly, how do i go about getting a PCM reset/tune. or "chip it" as some say. anything i can do myself or do i need to go to a garage for a pcm retune.
Old Jul 23, 2010 | 08:13 PM
blueblazer1982's Avatar
blueblazer1982 is on a distinguished road
for spark plugs go with ac delco only
i used platinum tip in mine and they work great.
i see alot guys with k&n i have that one myself. it fits well, but they are expensive.
for the pcm i believe you can send it and they re-program it i believe for more performance. a few guys on here have done it and say it works.
Old Jul 23, 2010 | 09:21 PM
cool thanks. (i work at a ford dealership) so i know what ford uses and recommends, but what is ac delco? is that the factory gm plugs and wires?
Old Jul 23, 2010 | 10:38 PM
yes ac delco is gm main supplier from what i've found. i don't use them for every part but i've found for spark plugs use only those...
a little side story: i went to meijers (local grocery store/general merchandise) i picked up enough spark plugs to change the blazer. put one of there plugs in and i brought up a service engine soon light. came on here found out about ac delcos and swapped my old ones for ac delcos. light went away and the truck ran better than before.
alot of other guys on here swear by them too. i've seen a few guys run ngk too.
Old Jul 24, 2010 | 12:33 AM
good enough answer for me, the lore around the shop says NGK are more for imports and run hotter than necessary for domestics. ac delco it is
im also planning on getting these, yay or nay?
http://www.familycar.com/store/?Ntt=...+1995&oes=true
http://www.familycar.com/store/index...olet&md=Blazer
Old Jul 24, 2010 | 06:23 AM
i'd go with the cold air intake but i don't think that throttle body spacer is going to give you any more powerr.
Old Jul 24, 2010 | 08:58 AM
i put a throttle body spacer in my 91 sierra with 350 and noticed a difference.
Old Jul 24, 2010 | 10:08 PM
was it tbi or carbed?
Old Jul 24, 2010 | 11:39 PM
Phil's Avatar
Don't bother with a TB spacer on these engines. Totally worthless. Just get a cold air intake and you'll be happy as a clam with it.
Old Jul 25, 2010 | 08:51 AM
ok. and it was tbi
