Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
Which one do you think is better and why
Old Dec 1, 2005 | 03:19 AM
ivannj's Avatar
ivannj is an unknown quantity at this point
Default Which one do you think is better and why
Granatelli Motor Sports Mass Airflow Sensors
or
Jet mass airflow sensor
The Jet is 10 bucks more but out of stock.
Old Dec 1, 2005 | 07:01 AM
Default RE: Which one do you think is better and why
Why do you ask? I am almost positive that our MAFs are the same used on the GM v8s... Our 4.3L will not outflow the MAF and many times, a new MAF requires a custom MAF table. That goes for just boring out your stock MAF. Anytime you increase the airflow through the MAF, the maf tables must be updated so that the computer knows that it is getting more air. More air + same fuel = LEAN condition!!!
Old Dec 1, 2005 | 07:07 AM
How a Mass Air Flow sensor works:
The MAF in our blazers uses elements (3 in most cases) which is given a specific voltage. The output of the sensor is changed by how much the airflow these elements sense. By opening up the cross-sectional area of the sensor, you are allowing more airflow through the sensor, but because the PCM is calibrated to the old cross-sectional area, it still thinks its only getting x cfm, when it is getting x+y cfm (y being the increase over x). Just because you increased the airflow through the sensor doesn't mean that the PCM will know its there. The elements are in specific spots and you would think that more airflow means that the elements would sense more airflow resulting in the PCM knowing there's more air, but that is not the case with non-adaptive/non-modifiable MAF tables in the PCM. Since everything is calibrated, things need to be updated in the PCM to take advantage and not cause problems.
Old Dec 1, 2005 | 03:58 PM
ivannj's Avatar
I am like a kid with a new toy looking to make it faster.
stonecoldsteele
Aug 15, 2014 09:50 PM
chris015
Engine & Internal
Jul 25, 2011 09:13 PM
nismo_2005
Tires and Wheels
Apr 23, 2011 12:08 PM
ZachL90
Aug 22, 2010 03:27 PM
Loud_01_Blazer
Feb 21, 2007 11:24 PM
